Jujkebox mode instability
Postby caribou » Mon Aug 25, 2014 1:49 pm
I've been using subsonic for years. There has been one function that has never worked correctly for me : the Jukebox mode.
As a matter of fact, I can trigger the problem very easily, using v5.0-beta and many Android clients (dsub, official & UltraSonic. All I need to do is to start a song in Jukebox mode, let it start to play for a few seconds, then select a new song to be played and start listening to it. Most of the time, the second song will not play and the status on the server just stops. Sometimes, stopping (i.e. using the Pause button) the first song & starting a new one helps.
Once in this situation, my only solution is to stop & start the subsonic process. Most of the time, the last song requested will start to play automagically. If someone can point me to some log file & can look into (server is on Ubuntu 14.04 so I already checked /var/subsonic/*log) I can help with debugging.
TIA,
...Louis
caribou
Users browsing this forum: No registered users and 52 guests
