Newb needs help with Podcasts
Postby spetras73 » Wed Aug 27, 2014 1:39 pm
For the life of me I can't figure out how to add a Podcast feed to my server. I've searched all these forums and used Google but I guess I'm blind.
I have version 4.9 (build 3853), running on Windows7 (64-bit, fwiw). My Podcast folder exists inside my main music directory and Subsonic is pointed to it.
Is there a HowTo somewhere? I'm sure it is easy but I just can't seem to grok it.
spetras73
Re: Newb needs help with Podcasts
Postby daneren2005 » Wed Aug 27, 2014 2:20 pm
In the web interface along the top you have a bunch of tabs. Click on the one which says Podcasts. It's to the right of Starred and to the left of Settings. I believe there is a podcast permission that you need to make sure your user has.
