disable duration check - HTTP Live Streaming
Postby tom_22 » Thu Aug 28, 2014 4:06 pm
I am using the "HTTP Live Streaming command" when streaming to my IOS device. This works fine for any 'real' files.
However, when I use a stream-source (e.g. my satellite-streaming device), I do get this error:
type: Status report
message: Unknown duration for media file: 64292
description: The server encountered an internal error that prevented it from fulfilling this request.
[Subsonic 4.9, Apache Tomcat/6.0.41]
Obviously, there is a duration-check, which fails with a continues stream.
Does anyone know how to get around this, or can this only be fixed within SS?
Tom
tom_22
Re: disable duration check - HTTP Live Streaming
Postby tom_22 » Sun Aug 31, 2014 4:11 pm
... I have manually updated the DURATION_SECONDS field of the MEDIA_FILE table, but still no success.
Has anyone successfully 'attached' a streaming source and forwarded the stream via 'HTTP Live Streaming' ?
Any ideas appreciated ... :-)
Tom
tom_22
