[SOLVED] Mac Issues, doesn't recognise Java...
Postby montymintypie » Fri Jan 09, 2009 5:19 am
EDIT: Decided not to bump this thread since it's so old. I have since upgraded to Leopard and everything works fine.
I've subscribed to this post, so will read and reply quickly to help. :D
I'm trying to get Subsonic to work on Mac OS X 10.4.11
I've put it in /private/var/subsonic/standalone, as Mac has var inside the private folder. Changed permissions so Subsonic has read/write access.
Running the .sh script in Terminal gives me this:
/private/var/subsonic/standalone/subsonic.sh: line 16: /bin/java: No such file or directory
Any help here? I DO have Java, I know that for a fact. I don't think that $JAVA_HOME is defined properly in Mac.
Thanks in advance!
Will
montymintypie
Re: Mac Issues, doesn't recognise Java...
Postby twiztar » Fri Jan 09, 2009 9:22 am
montymintypie wrote:I've subscribed to this post, so will read and reply quickly to help. :D
Thanks in advance!
Will
modify your subsonic.sh:
SUBSONIC_HOME=/private/var/subsonic/standalone
Next, find out where your java is, usually most *nix can use which to do so:
which java
take the result and modify your subsonic.sh again:
replace
$JAVA_HOME/bin/java
with the full path to your java binary
twiztar
Postby montymintypie » Fri Jan 09, 2009 12:25 pm
Thanks! Almost fixed, now I get this:
Unable to access jarfile subsonic-booter-jar-with-dependencies.jar
Tried sudo'ing it too, no luck. The file is definitely there.
Here's my sh file so far:
#!/bin/sh
# The directory where Subsonic will create files. Make sure it is writable.
# The port on which Subsonic will listen for incoming HTTP traffic.
SUBSONIC_PORT=8080
# The context path (i.e., the last part of the Subsonic URL).  Typically "/" or "/subsonic".
SUBSONIC_CONTEXT_PATH=/
# The memory limit (max Java heap size) in megabytes.
MAX_MEMORY=64
/usr/bin/java -Xmx${MAX_MEMORY}m  -Dsubsonic.home=${SUBSONIC_HOME} -Dsubsonic.port=${SUBSONIC_PORT} \
-Dsubsonic.contextPath=${SUBSONIC_CONTEXT_PATH} -jar subsonic-booter-jar-with-dependencies.jar
Replacing ${SUBSONIC_CONTEXT_PATH} with the full path to subsonic doesn't work either.
Thanks in advance!
Will
montymintypie
Postby twiztar » Fri Jan 09, 2009 2:06 pm
Try adding full path to the jar file, e.g ${SUBSONIC_HOME}/subsonic-booter-jar-with-dependencies.jar
edit:
If that doesn't work, you can modify the classpath, the command line should then look like this:
-Dsubsonic.contextPath=${SUBSONIC_CONTEXT_PATH} -cp ${SUBSONIC_HOME} -jar subsonic-booter-jar-with-dependencies.jar
twiztar
Users browsing this forum: No registered users and 66 guests
