SOLVED Updating from older version
Postby wurrrlitzer » Mon Sep 22, 2014 9:38 am
Hello there!
I'm currently running Subsonic 4.9 on a Cubietruck with Debian (ARM) and Java 8 on it. I'd like to update to Subsonic 5.0 but I have yet to find information about the update process. For Windows boxes the installation instructions (http://www.subsonic.org/pages/installation.jsp) say that upgrading is pretty simple because config data won't be overwritten. Somehow I have the feeling that this might not be the case when trying to update on linux with a deb package.
Any hints about what preparations I should be making or, generally, how to best apply the update?
Thanks a lot in advance!
wurrrlitzer
Re: Updating from older version
Postby wurrrlitzer » Mon Sep 22, 2014 2:33 pm
I'm an impatient person, I simply couldn't wait for an answer. So I simply tried:
downloaded the latest deb package, then
sudo dpkg -i subsonic5.0.deb
old version was simply replaced with the new version while keeping all settings.
Might be a good idea to add this info to your installation instructions as a hint for upgraders?
Thanks for your great work on Subsonic, sindre - much apprechiated
wurrrlitzer
Re: SOLVED Updating from older version
Postby wurrrlitzer » Tue Sep 23, 2014 6:29 am
Another problem I encountered after upgrading: The web player did play mp3s but wasn't transcoding other formats.
Subsonic log had this:
[2014-09-23 08:19:16,139] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) /var/subsonic/transcode/ffmpeg: 1: /var/subsonic/transcode/ffmpeg: Syntax error: "(" unexpected
Turns out that at /var/subsonic/transcode/ I had an old version of ffmpeg.
I deleted the old version of ffmpeg and did a
ln -s /usr/bin/ffmpeg /var/subsonic/transcode/ffmpeg
Problem solved. Since I did the very same thing after installing Subsonic 4.9 I expect that the outdated version of ffmpeg comes with the Subsonic deb package. Maybe this problem could be fixed some day.
wurrrlitzer
Users browsing this forum: No registered users and 96 guests
