Status: No Router Found (with a twist!)
Postby gCrusher » Tue Sep 23, 2014 5:07 am
Hello!
I've been using Subsonic for a few weeks now, loving having access to music on the go. Web browsers, phone app, it all worked with my custom subsonic dot org address.
One thing I noticed coming up a lot in feature request for this application was the ability to limit access of certain files for certain users. I then saw it posted that Madsonic offered this option. Thought I'd give it a shot, but it didn't install properly (antivirus kept popping up, denying parts of the installation). I had to manually uninstall it and remove the windows service since the uninstall option was one of the things killed by the antivirus.
Now, Subsonic no longer is forwarding, giving the above error where there was none previously. Uninstall/reinstall isn't helping. I'm sure the port forwarding is fine, because it worked before the Madsonic issue. Furthermore, I'm using RDC to access the computer with Subsonic. If there was no router, I wouldn't be able to do so.
Really, really annoyed, but I only have myself to blame. If it isn't broke...
gCrusher
Re: Status: No Router Found (with a twist!)
Postby gurutech » Tue Sep 23, 2014 2:34 pm
Check your AV and your windows firewall to make sure it's not blocking port 4040.
gurutech
