FLAC not playing
FLAC not playing
Postby tmwsiy » Fri Sep 26, 2014 10:20 pm
Have not changed transcoding options and using default settings.
FLAC was never an issue but stopped working.
PC. Am using 4.8 as it is the only version that works properly with iSub.
This from the log:
[9/26/14 6:16:47 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Stream #0.0: Audio: flac, 48000 Hz, stereo, s16
[9/26/14 6:16:47 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) Unrecognized option 'b:a'
[9/26/14 6:16:47 PM EDT] DEBUG InputStreamReaderThread (c:\subsonic\transcode\ffmpeg) c:\subsonic\transcode\ffmpeg: failed to set value '128k' for option 'b:a'
What is going on? Thanks.
tmwsiy
Re: FLAC not playing
Postby tmwsiy » Mon Sep 29, 2014 3:08 am
BUMP
tmwsiy
Postby saphyrre » Tue Oct 07, 2014 4:19 pm
Had exactly the same problem (on Centos 6.5), solved by updating ffmpeg to latest version. Unfortunately official repos still have the old version, but there is a very good guide for compiling from source at http://trac.ffmpeg.org/wiki/CompilationGuide/Centos
saphyrre
Postby jokah » Tue Oct 07, 2014 4:46 pm
Where does /var/subsonic/transcode/ffmpeg come from? It's a little non-intuitive to upgrade ffmpeg but still have to fix the version that lives in a subsonic directory.
jokah
Postby saphyrre » Tue Oct 07, 2014 4:59 pm
jokah wrote:Where does /var/subsonic/transcode/ffmpeg come from? It's a little non-intuitive to upgrade ffmpeg but still have to fix the version that lives in a subsonic directory.
You're absolutely right, you should not keep a different binary in that folder (unless you have some very specific needs), but rather use a symlink (as a previous post here suggested).
saphyrre
