Constant error in Subsonic (resolved)
Postby nabab » Sat Oct 18, 2014 7:59 am
Without apparent reason (no change on the server's libraries, on the library, in the users), Subsonic opens on an error, and it's now impossible to use it.
As it says to post the error on the forum, here it is. And thanks for your help!
Error
Exception org.springframework.jdbc.BadSqlGrammarException
Message PreparedStatementCallback; bad SQL grammar [select id, name, type, username, ip_address, auto_control_enabled, last_seen, cover_art_scheme, transcode_scheme, dynamic_ip, technology, client_id from player where id=?]; nested exception is java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: ""
Java version Sun Microsystems Inc. 1.6.0_32
Operating system Linux 3.13.0-35-generic
Server jetty-6.1.x
Memory Used 85 of 133 MB
Stack trace org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [select id, name, type, username, ip_address, auto_control_enabled, last_seen, cover_art_scheme, transcode_scheme, dynamic_ip, technology, client_id from player where id=?]; nested exception is java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: ""
at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:97)
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:120)
at net.sourceforge.subsonic.dao.PlayerDao.getPlayerById(PlayerDao.java:88)
at net.sourceforge.subsonic.service.PlayerService.getPlayerById(PlayerService.java:175)
at net.sourceforge.subsonic.service.PlayerService.getPlayer(PlayerService.java:94)
at net.sourceforge.subsonic.service.PlayerService.getPlayer(PlayerService.java:64)
at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:144)
Caused by: java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: ""
at org.hsqldb.jdbc.jdbcPreparedStatement.setParameter(Unknown Source)
at org.hsqldb.jdbc.jdbcPreparedStatement.setString(Unknown Source)
at org.springframework.jdbc.core.StatementCreatorUtils.setValue(StatementCreatorUtils.java:335)
at org.springframework.jdbc.core.StatementCreatorUtils.setParameterValueInternal(StatementCreatorUtils.java:217)
at org.springframework.jdbc.core.StatementCreatorUtils.setParameterValue(StatementCreatorUtils.java:145)
at org.springframework.jdbc.core.ArgPreparedStatementSetter.setValues(ArgPreparedStatementSetter.java:51)
at org.springframework.jdbc.core.JdbcTemplate$1.doInPreparedStatement(JdbcTemplate.java:646)
... 64 more
nabab
Re: Constant error in Subsonic
Postby kyomi7502 » Mon Oct 20, 2014 12:17 pm
I noticed this line in your log:
That is incredibly old... update to Java 7 (Or the latest Java 6 if that is impossible) and try again and let me know how it turns out :)
kyomi7502
Postby nabab » Tue Oct 21, 2014 8:56 am
Thanks for your answer, but actually: there's already Java 7 on the system, and after realizing other users had no problem, I just removed all my cookies and offline content, and everything works fine now. So apparently nothing to do with the software...
Sorry for the hassle!
nabab
Users browsing this forum: No registered users and 35 guests
