Can't use Web Player outside of local network.
Postby simonsonics » Thu Oct 30, 2014 5:38 pm
Hi All.
Curious problem: I can't get the Subsonic web player to work outside of my network. Here's the catch: I CAN use Subsonic from the iSub app. Port forwarding is set up properly via 8085. My router is a Linksys wrt54GL running the supplied firmware. My subsonic redirect address is simonsonics.subsonic.org. It works fine on my iPhone over 4G. When I go to the same address via firefox from a computer outside of my network, the redirect works, but Subsonic fails to show the login screen, and I get a generic 'unable to connect' message in Firefox. I've also tested IE and it doesn't work either.
What conditions could lead to subsonic working ok through a phone app client and NOT ok using the built-in web player?
Thanks much.
-K
ps. I'm a programmer by trade so I understand what should be happening, but I do have a soft spot in my skill set for troubleshooting networking issues.
pps. Using Subsonic Premium version 5.00 Build 4100
simonsonics
Re: Can't use Web Player outside of local network.
Postby matka » Sat Nov 01, 2014 6:12 pm
Is it at work ? Is it possible that your work firewall blocks all ports except for 80 ? and perhaps 8080 ? They did that in my place.
George
matka
Postby alphawave7 » Sat Nov 01, 2014 8:03 pm
Very odd, as I get to the login screen no problem..using Chromebook. It even says 'hello!' :)
