Replacement Router
Replacement Router
Postby richardgrosser » Fri Oct 31, 2014 6:00 pm
I have ATT Uverse service with a Motorola NVG589 router. Subsonic worked perfectly. Router blew up and was replaced and now I cannot access subsonic on any device. Set up NAT the same but no joy. Any Ideas?
richardgrosser
Re: Replacement Router
Postby alphawave7 » Sat Nov 01, 2014 8:14 pm
UNCHECK 'Automatically configure' in Settings Network, then manually configure the new router to pass your port. Reboot and test @ canyouseeme.org for your port. Wan will only work when it passes the canyouseeme.org test.
Postby richardgrosser » Sun Nov 02, 2014 6:18 pm
I finally figured it out. This is a very weird router.
Thank you for the reply
richardgrosser
Postby msujdog » Mon Nov 16, 2015 6:05 pm
I would love to hear what you did. I'm using the NVG599 which is very similar. Can't get it to unlock port 80. Apparently this has something to do with the TV and DVR service. Ports 81-89 are open apparently from what I'm reading. Can Subsonic use one of these instead?
msujdog
Users browsing this forum: Google [Bot] and 15 guests
