3.6 fails for me
3.6 fails for me
Postby Lozzy » Wed Jan 14, 2009 4:49 pm
I've been using 3.5 beta2 for a while now - very nice.
When i tried 3.6 betas 1 & 2 i get the same problem in both cases, no initial web page.
In both IE and Firefox, they just sit there waiting to connect and eventually time out.
I did the usual port number change and a restart but nada...anyone else had this problem?
regards
Lozzy
Lozzy
Postby Lozzy » Thu Jan 29, 2009 7:25 pm
sorry, i don't quite understand what you're saying or asking..
Lozzy
Postby Lozzy » Thu Jan 29, 2009 7:27 pm
thanks, now i understand :)
Lozzy
Postby Lozzy » Wed Feb 04, 2009 12:27 am
I did all of the above, but still no luck.
Now the full 3.6 is out, and it's behaving the same.
I run windows 2000 incidentally.
Anyone else having this problem??
Lozzy
Lozzy
Postby sindre_mehus » Wed Feb 04, 2009 4:39 am
Could you please check the logs:
c:\Program Files\Subsonic\log\subsonic-service.log
c:\subsonic\subsonic.log
Postby Lozzy » Wed Feb 04, 2009 10:00 am
Hi Sindre,
ok I've uploaded them to http://ge4r.net for you to look at.
regards
Lozzy
Lozzy
Postby sindre_mehus » Wed Feb 04, 2009 10:22 am
Hm, everything looks normal in the logs.
And you get nothing if you go to http://localhost:8080/ ?
Postby Lozzy » Wed Feb 04, 2009 10:27 am
I get firefox or IE sitting there..."loading" but no resulting page.
re the logs, should I not worry about the warning lines at the bottom of the agent log then?
Lozzy
Lozzy
Postby jannuh » Sat Feb 07, 2009 6:45 pm
Had same problem overhere (Subsonic on WinXP)
Had to open port 8081 on Win Firewall, in V3.5 just had to give subsonic permission.
After opening port 8081 all okay (in- and ext player doesn't work, but I'll ask that in an other topic)
jannuh
Postby jannuh » Sun Feb 08, 2009 8:14 am
Found the problem with the firewall:
In last version the exe file was subsonic.exe this is now changed in subsonic-service.exe
So you have to add the new exe file to your Win Firewall
jannuh
Postby Lozzy » Sun Feb 08, 2009 10:17 am
Ok, thanks for the tip Jannuh.
Sadly since i'm running windows 2000, the firewall isn't the issue, since it doesn't have one built in :)
Until Sindre gets back to me with a solution, or things to try, I'm stuck on version 3.5 since that works.
It's got to be something that got changed between 3.5 and 3.6
Lozzy
Lozzy
Postby jannuh » Tue Feb 10, 2009 3:11 pm
My last solution with the exe file & firewall "fooled"Subs. for 1 day ;-)
In testing I deleted the cookie, no result.. (and several other things..)
I did go to Subs. via my external link, a subdomain of my privat domain; now I did go to Sub via my own's server-pc ip numer, everything went smooth, als via internal ip adress.
It seems other users have no problems with this issue, jsut local PC :-)
jannuh
