location of subsonic config in Freenas Plugin
Postby yajrendrag » Sun Nov 16, 2014 10:04 pm
Trying to enable ssl in subsonic - i can see from search (item #4 here: http://www.subsonic.org/pages/getting-started.jsp) that one needs to edit /etc/default/subsonic or /etc/sysconfig/subsonic for various linux... I have subsonic installed in a freenas plugin... can't seem to find a file that resembles one of these with any contents containing SUBSONIC_ARGS.
any pointers appreciated.
yajrendrag
Re: location of subsonic config in Freenas Plugin
Postby nucshuco » Tue Jan 06, 2015 6:16 pm
Were you able to find the config file? I have freenas also and cant find it.
nucshuco
Postby mr3man » Fri Jan 23, 2015 9:51 pm
Hey folks. Here's what I did on FreeNAS 9.3. Install the Subsonic 5.1 plugin. Go to Plugins > Installed Tab > Slide Service Status to On. Then expand plugins in the left pane. You'll see Plugins > Subsonic. Click on Subsonic and you'll see the familiar "Max Memory, Enable SSL, Port, etc".
mr3man
