iSub not showing files in a folder that are visible via web
Postby Mauro80 » Wed Nov 19, 2014 5:13 pm
Hello all,
Recently I've been having an issue.
I have created a folder with several tracks in it. If is browse it using iSub, I can clearly see there are missing files.
On the other hand, if I access Subsonic via web, then I can see everything.
The other strange thing is that if I use the search feature in iSub I can find the files missing, however, I cannot see them in the corresponding folder.
Any ideas?
M.-
Mauro80
Re: iSub not showing files in a folder that are visible via
Postby cwojeski » Wed Nov 26, 2014 10:51 pm
I'm having the same issue. Any help is most appreciated.
cwojeski
Postby csphead » Tue Feb 10, 2015 4:18 pm
I had the same issue and the only way I've found to correct it was to roll back to Subsonic 4.9. I had the same problems with Subsonic 5.0 and 5.1 with iOS 7 on an iphone 4S and iOS 8 on an iphone 6.
csphead
Users browsing this forum: Google [Bot] and 28 guests
