Error on homescreen
Error on homescreen
Postby imral3 » Thu Nov 20, 2014 9:22 pm
How do I resolve the following error which shows in each of the homescreens panes?
Exception org.springframework.jdbc.BadSqlGrammarException
Message PreparedStatementCallback; bad SQL grammar [select id, name, type, username, ip_address, auto_control_enabled, last_seen, cover_art_scheme, transcode_scheme, dynamic_ip, technology, client_id from player where id=?]; nested exception is java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: ""
Java version Oracle Corporation 1.7.0_71
Operating system Windows 8 6.2
Server jetty-6.1.x
Memory Used 48 of 135 MB
Stack trace org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [select id, name, type, username, ip_address, auto_control_enabled, last_seen, cover_art_scheme, transcode_scheme, dynamic_ip, technology, client_id from player where id=?]; nested exception is java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: ""
at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:97)
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:120)
at net.sourceforge.subsonic.dao.PlayerDao.getPlayerById(PlayerDao.java:88)
at net.sourceforge.subsonic.service.PlayerService.getPlayerById(PlayerService.java:175)
at net.sourceforge.subsonic.service.PlayerService.getPlayer(PlayerService.java:94)
at net.sourceforge.subsonic.service.PlayerService.getPlayer(PlayerService.java:64)
at net.sourceforge.subsonic.controller.NowPlayingController.handleRequestInternal(NowPlayingController.java:51)
Caused by: java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: ""
at org.hsqldb.jdbc.jdbcPreparedStatement.setParameter(Unknown Source)
at org.hsqldb.jdbc.jdbcPreparedStatement.setString(Unknown Source)
at org.springframework.jdbc.core.StatementCreatorUtils.setValue(StatementCreatorUtils.java:335)
at org.springframework.jdbc.core.StatementCreatorUtils.setParameterValueInternal(StatementCreatorUtils.java:217)
at org.springframework.jdbc.core.StatementCreatorUtils.setParameterValue(StatementCreatorUtils.java:145)
at org.springframework.jdbc.core.ArgPreparedStatementSetter.setValues(ArgPreparedStatementSetter.java:51)
at org.springframework.jdbc.core.JdbcTemplate$1.doInPreparedStatement(JdbcTemplate.java:646)
... 64 more
imral3
