Error scanning media
Postby dotJerdot » Fri Nov 21, 2014 4:34 pm
Hello, I have been running Subsonic on my WHS 2011 PC for about 3 to 4 years now without any trouble. I noticed the other day that it will now not scan my media and all of my songs are missing. I receive this error when looking at the log.
I tried to reinstall Java version 8 Update 25 build 1.8.0_25-b18 yet it still has the same error.
[2014-11-21 11:24:59,574] INFO MediaScannerService - Starting to scan media library.
[2014-11-21 11:25:01,306] ERROR MediaScannerService - Failed to scan media library.
org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:71)
at net.sourceforge.subsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:138)
at net.sourceforge.subsonic.service.MediaFileService.updateChildren(MediaFileService.java:356)
at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:192)
at net.sourceforge.subsonic.service.MediaScannerService.scanFile(MediaScannerService.java:228)
at net.sourceforge.subsonic.service.MediaScannerService.doScanLibrary(MediaScannerService.java:178)
at net.sourceforge.subsonic.service.MediaScannerService.access$000(MediaScannerService.java:48)
at net.sourceforge.subsonic.service.MediaScannerService$2.run(MediaScannerService.java:147)
Caused by: java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
... 11 more
[2014-11-21 11:25:01,454] INFO PlaylistService - Starting playlist import.
[2014-11-21 11:25:01,455] INFO PlaylistService - Completed playlist import.
[2014-11-21 11:25:01,455] INFO PlaylistService - Starting playlist statistics update.
[2014-11-21 11:25:01,463] INFO PlaylistService - Completed playlist statistics update.
dotJerdot
Re: Error scanning media
Postby dotJerdot » Sat Nov 22, 2014 12:54 pm
Deleted the db folder and relaunched. It worked after that so I just restored the whole subsonic folder from a previous backup and everything is working as it was.
dotJerdot
Postby alphawave7 » Sat Nov 22, 2014 1:23 pm
S1000 error is a corrupt db...search S1000 shows your fix is common as well as a way to preserve settings. Backups are always a good thing regardless.
Users browsing this forum: No registered users and 88 guests
