Playback does not start automatically without transcoding
Postby chit112 » Tue Dec 02, 2014 10:49 am
I am experiencing a strange problem in Subsonic using the built in webplayer: When I have a playlist playing, the music will not start streaming in some cases when the playlist moves to a new song. Instead the flash player will show that it is downloading the full song, but never starts playing it. If i click the song progress bar to skip a bit into the song, then it starts playing immediately. Interestingly, I have found that if I force transcoding (by setting the allowed bitrate to something so low that all songs will be transcoded) then the problem stops happening. Unfortunately that also greatly decreases the quality of the audio, so it is not a very good workaround. The issue seems to occur with simple types of files like 128 Kbps MP3's which should not normally require any kind of transcoding.
Has anyone else experienced this problem - and any suggestions what I could do to solve it?
chit112
