New error message
New error message
Postby Mattyb123 » Fri Dec 19, 2014 5:50 pm
Message PreparedStatementCallback; SQL [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
Java version Sun Microsystems Inc. 1.6.0_29
Server jetty-6.1.x
Memory Used 91 of 145 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:71)
at net.sourceforge.subsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:155)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:118)
at net.sourceforge.subsonic.service.MusicIndexService.createSortableArtists(MusicIndexService.java:145)
at net.sourceforge.subsonic.service.MusicIndexService.getIndexedArtists(MusicIndexService.java:61)
at net.sourceforge.subsonic.controller.LeftController.getMusicFolderContent(LeftController.java:220)
at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:142)
Caused by: java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
... 63 more
I have erased and re-downloaded the program.
Ideas?
Mattyb123
Re: New error message
Postby Mattyb123 » Fri Dec 19, 2014 5:52 pm
Previous message was on the sidebar. Here is the main error message:
Exception java.lang.NullPointerException
Message null
Server jetty-6.1.x
Memory Used 110 of 145 MB
Stack trace java.lang.NullPointerException
at net.sourceforge.subsonic.service.SecurityService.getMusicFolderForFile(SecurityService.java:238)
at net.sourceforge.subsonic.service.SecurityService.isInMusicFolder(SecurityService.java:233)
at net.sourceforge.subsonic.service.SecurityService.isReadAllowed(SecurityService.java:201)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:98)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:80)
at net.sourceforge.subsonic.controller.NowPlayingController.handleRequestInternal(NowPlayingController.java:54)
Mattyb123
Postby Mattyb123 » Fri Dec 19, 2014 9:58 pm
All of the music is still there. It just won't play or update the folders.
Thoughts?
Mattyb123
Postby alphawave7 » Sat Dec 20, 2014 3:12 am
Corrupt db...try 'Clean Up Database' and see if that clears it...
Postby Mattyb123 » Sat Dec 20, 2014 3:09 pm
No luck....still no music playing.
Mattyb123
Postby alphawave7 » Sun Dec 21, 2014 6:55 am
Mattyb123 wrote:No luck....still no music playing.
Did you rebuild the database after cleanup? If so, you might need to delete the db folder and restart. Settings may get fried unless you have/had a backup.
Postby Mattyb123 » Mon Dec 22, 2014 1:19 am
That's Greek to me, honestly.
So I can't imagine I did unless there's a button for that.
Mattyb123
Postby alphawave7 » Tue Dec 23, 2014 1:18 am
Mattyb123 wrote:That's Greek to me, honestly.
It is a button of sorts...right above 'Clean Up Database', 'Scan Media Folders Now'. If this doesn't resolve it,then the db folder deletion would be your next step.
Postby Mattyb123 » Tue Dec 23, 2014 1:34 pm
I erased the db folder under c:/subsonic and I'm back up.
Mattyb123
Users browsing this forum: Google [Bot] and 28 guests
