App wont show music files
Postby Edi.I » Sun Dec 21, 2014 1:17 pm
im new to subsonic.
i set up a basic test server and tried to access the files on my phone\tablet (tried it on 3 different devices with same results).
the connection test is successful, i can see the folders that i have set up, but they are empty.
i have tried going to my server site from my mobile device and everything works well. so i assume that the files are online.
has anyone encountered that problem in the past? and if you did - how do you solve it?
Thanks a lot,
Edi.
Edi.I
Re: App wont show music files
Postby jamburglar » Thu Jan 08, 2015 7:44 am
I am having a similar problem. Any new/recent folders I've added show up in apps, BUT when I open the folders they appear blank with no files contained inside the folder. On the subsonic website, the folders and the files both appear—but via iSub, Submariner, and other apps, the files don't show up (the folder is just blank). Hope that makes sense.
Currently using Subsonic 5.1.beta1 and Java Version 8 Update 25 on Windows 7 64-bit.
jamburglar
