Importing playlists
Importing playlists
Postby PeteF3 » Thu Dec 25, 2014 3:56 am
Subsonic gives me an error message every time I try to import an M3U or XSPF file created in MediaMonkey. Either "Failed to parse XSPF playlist" or "Failed to import playlist. No songs in the playlist were found" for an M3U file.
The only workaround is to use the Export All Playlists function in MM, which is slow, clumsy, and over-the-top and just plain unacceptable as a solution. What format can I put an M3U or XSPF file in so that Subsonic can recognize it?
PeteF3
Re: Importing playlists
Postby gadevoi » Thu Jan 15, 2015 5:17 pm
I have the same problem... Even the "playlist folder" option does nothing :(
How could i see what is going wrong with the import? Is there a preferred file format for playlists (I'm currently using M3U).
I'm making my playlists with beets and my paths have only ASCII characters in them.
gadevoi
Postby tnt533 » Sat May 30, 2015 9:19 pm
I've had the same issue exporting a playlist from Rhythmbox in .pls format and then getting the no songs found error when importing it into Subsonic.
It's been almost 4 months since this thread has had any activity. Have either of you figured out the solution on your own?
*EDIT*
I attempted all formats Subsonic says it can import and I managed to get a .m3u playlist saved to a file from VLC to import successfully. This is on a 64bit Ubuntu Mate 15.04 system running Subsonic 5.2.1 (build 4428) with Oracle Java 8.
tnt533
Postby rspagan » Sat Jul 04, 2015 3:47 am
I get this error because I have a weird setup.
Because my car's stereo uses an iPod for ALAC decoding, I use iTunes on Windows. So, I create playlists with iTunes, then export them to a playlists folder locally on my Windows machine's hard disk. I then rsync my Windows machine's music folder to a NAS device, which has fault tolerance and is used as an NFS/SMB share. I mount that NAS share to my Fedora box, which runs SubSonic.
Now I understand that the reason for the "Failed to import playlist. No songs in the playlist were found." error is because of the paths inside of the M3U file. iTunes will export the absolute path for each track. When you're on a Windows computer, this is "X:\Music\Artist\Artist - Album (year)\## - Song.m4a" or similar... which is different than what a Linux box would need to see, which would be something like "/home/music/Artist/Artist - Album (year)\## - Song.m4a" . If I edit the M3U file to point to the Linux style paths, then SubSonic will not throw the error and will import the playlist.
What I DON'T understand, and it's been bugging me for the last few versions, is that when upgrading or installing a fresh instance of SubSonic on my Linux box which loads a samba share which is a duplicate of a Windows file structure including playlists that have Windows paths, SubSonic will import those playlists with no problem and they work. I get new automatically imported playlists with incorrect paths each time I upgrade or reinstall SubSonic, but I cannot get SubSonic to just automatically import the playlist folder when it scans or restarts.
Anyone have a workaround? Ideally, I'd like the playlists to be automatically imported when doing a scan, since I update playlists pretty frequently since the majority of my music listening in the car with the iPod (it's lossless and my sound system is as good as a car listening environment can get), but I'd like to have the same playlists in SubSonic for the days I use transit or have desk work to do.
rspagan
