Last.FM Support Bug & some help needed
Postby kopf » Sat Jan 17, 2009 7:23 pm
first of all, I've noticed a bug with the last.fm support. I began playing a song by X. Then after 10 seconds (the song is about 4 minutes long), I switched to a different song by artist Y. I listened to it entirely, and went on to the next song by artist Y.
On my last.fm account, the first song by artist X was recorded, and the last song by artist Y.
Songs should only be registered as having been played with last.fm when they're 50% over (or 100% over, if that's the best that's possible), for example.
Also, I need a little bit of help - how do I make the web player the default player?
Thanks.
kopf
Postby kopf » Sat Jan 17, 2009 7:44 pm
Also, there is what seems to be a boolean option called "Non-SSL Stream port". If the default is 0, meaning stuff is streamed over SSL, does that mean webpage views are too?
If not, how do I make everything be sent over https?
kopf
