Recent transcoding issue
Postby cnschulz » Thu Jan 01, 2015 4:35 am
Howdy,
I *was* using 5.0beta1 and it was working fine on Dec 21. Went to use it again today and noticed all songs only load about 3 seconds (with no sound). There was a transcoding error in the logs so I instantly blamed Java.
I upgraded to 5.1beta1 and openJDK7 and still got the same error. I turned off transcoding and playing of mp3's works fine.
I have some AAC's and other file formats so I *think* i need transcoding to work (I dont care about bandwidth)
Is there something I can do to figure out this problem and fix the issue? Log Attached...
[2015-01-01 14:55:46,543] INFO DaoHelper - Checking database schema.
[2015-01-01 14:55:52,933] INFO DaoHelper - Done checking database schema.
[2015-01-01 14:55:53,623] INFO VersionService - Resolved local Subsonic version to: 5.1.beta1
[2015-01-01 14:55:55,852] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Fri Jan 02 03:00:00 EST 2015
[2015-01-01 14:55:56,090] INFO UPnPService - Starting UPnP service...
[2015-01-01 14:55:56,661] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Thu Jan 01 15:00:56 EST 2015
[2015-01-01 14:55:59,851] INFO UPnPService - Enabling UPnP/DLNA media server
[2015-01-01 14:55:59,852] INFO UPnPService - Starting UPnP service - Done!
[2015-01-01 14:56:06,224] WARN NetworkService - Failed to create port forwarding.
java.lang.Exception: null: Error: Current state of service prevents invoking that action. Connection error or no response received.
   at net.sourceforge.subsonic.service.upnp.ClingRouter.addPortMappingImpl(ClingRouter.java:116)
   at net.sourceforge.subsonic.service.upnp.ClingRouter.addPortMapping(ClingRouter.java:89)
   at net.sourceforge.subsonic.service.NetworkService$PortForwardingTask.execute(NetworkService.java:149)
   at net.sourceforge.subsonic.service.NetworkService$Task.run(NetworkService.java:306)
   at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
   at java.util.concurrent.FutureTask$Sync.innerRunAndReset(FutureTask.java:351)
   at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:178)
   at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:165)
   at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:267)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1146)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
   at java.lang.Thread.run(Thread.java:701)
[2015-01-01 15:00:56,656] INFO PodcastService - Starting scheduled Podcast refresh.
[2015-01-01 15:00:56,797] INFO PodcastService - Completed scheduled Podcast refresh.
[2015-01-01 15:00:58,694] INFO VersionService - Resolved latest Subsonic final version to: 5.0
[2015-01-01 15:00:58,695] INFO VersionService - Resolved latest Subsonic beta version to: 5.1.beta1
[2015-01-01 15:01:16,723] WARN CoverArtController - Failed to process cover art /var/music/the Lovely Sparrows/Glad Rangers 7_/01 Glad Rangers.mp3: java.lang.NullPointerException
   at java.io.ByteArrayInputStream.<init>(ByteArrayInputStream.java:106)
   at net.sourceforge.subsonic.controller.CoverArtController.getImageInputStream(CoverArtController.java:260)
   at net.sourceforge.subsonic.controller.CoverArtController.access$600(CoverArtController.java:73)
   at net.sourceforge.subsonic.controller.CoverArtController$CoverArtRequest.createImage(CoverArtController.java:364)
   at net.sourceforge.subsonic.controller.CoverArtController.getCachedImage(CoverArtController.java:228)
   at net.sourceforge.subsonic.controller.CoverArtController.handleRequest(CoverArtController.java:119)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:715)
[2015-01-01 15:04:51,893] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/var/music/A Flock Of Seagulls/20 Classics Of The 80's/01 Space Age Love Song.mp3] [-map] [0:0] [-v] [0] [-f] [au] [-]
[2015-01-01 15:04:53,806] ERROR JukeboxService - Error in jukebox: javax.sound.sampled.LineUnavailableException
   at org.classpath.icedtea.pulseaudio.PulseAudioMixer.openImpl(PulseAudioMixer.java:714)
   at org.classpath.icedtea.pulseaudio.PulseAudioMixer.openLocal(PulseAudioMixer.java:588)
   at org.classpath.icedtea.pulseaudio.PulseAudioMixer.openLocal(PulseAudioMixer.java:584)
   at org.classpath.icedtea.pulseaudio.PulseAudioMixer.open(PulseAudioMixer.java:579)
   at org.classpath.icedtea.pulseaudio.PulseAudioDataLine.open(PulseAudioDataLine.java:94)
   at org.classpath.icedtea.pulseaudio.PulseAudioSourceDataLine.open(PulseAudioSourceDataLine.java:75)
   at org.classpath.icedtea.pulseaudio.PulseAudioSourceDataLine.open(PulseAudioSourceDataLine.java:90)
   at net.sourceforge.subsonic.service.jukebox.AudioPlayer.<init>(AudioPlayer.java:60)
   at net.sourceforge.subsonic.service.JukeboxService.play(JukeboxService.java:112)
   at net.sourceforge.subsonic.service.JukeboxService.updateJukebox(JukeboxService.java:80)
   at net.sourceforge.subsonic.ajax.PlayQueueService.convert(PlayQueueService.java:415)
   at net.sourceforge.subsonic.ajax.PlayQueueService.doSkip(PlayQueueService.java:117)
   at net.sourceforge.subsonic.controller.RESTController.jukeboxControl(RESTController.java:836)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
   at java.lang.reflect.Method.invoke(Method.java:622)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
   at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
   at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
   at org.mortbay.servlet.UserAgentFilter.doFilter(UserAgentFilter.java:81)
   at org.mortbay.servlet.GzipFilter.doFilter(GzipFilter.java:148)
   at net.sourceforge.subsonic.security.RESTRequestParameterProcessingFilter.doFilter(RESTRequestParameterProcessingFilter.java:105)
   at net.sourceforge.subsonic.filter.RESTFilter.doFilter(RESTFilter.java:60)
cnschulz
Users browsing this forum: No registered users and 55 guests
