Unpacking uploads under linux
Postby rocketpants » Tue Jan 20, 2009 8:47 am
Hi all,
I'm running Subsonic 3.6 under Ubuntu 8.04 and discovered the following problem with unpacking uploaded files.
Subsonic unpacks the files with the following name
<ZIP NAME>\<FILE NAME>
which is fine is you are using windows as it will put all file names in a directory with the same name as the ZIP, this just creates a bunch of files in the upload directory as indicated above. It should be unpacking them as <ZIP NAME>/<FILE NAME> to create the sub directory.
I dont think that I've made a stupid error here but please feel free to point out if I have and consider the issues for the next release...
RP
rocketpants
Postby jigsaw » Tue Jan 20, 2009 7:17 pm
I'm running Subsonic 3.6beta2 on a Fedora Core 6 server. Uploading zip-files works just as it should for me at least.
I've tried it with a zip-file containing several levels of sub directories as well. Subsonic decompress the archive just fine, then deletes the zip-file.
jigsaw
