Wrong IP Address used by Subsonic.org
Postby michelm » Fri Jan 09, 2015 10:23 pm
I'm testing subsonic now for a few days and subsonic server is working from within my home network.
When I try to access it by using the MyName.subsonic.org address, the browser can not acces the page and returns a wrong WAN IP adress.
I have checked my WAN IP address and also checked if port 8080 which I'm using is open. I've checked it at CanyouSeeMe.org. But the IP address that gets translated by the browser when I type in MyName.subsonic.org is not my real WAN IP address.
Can you help me with this ?
michelm
Re: Wrong IP Address used by Subsonic.org
Postby gurutech » Mon Jan 12, 2015 11:28 pm
It's a known issue with the DNS servers that Subsonic uses. If you can type the internal IP address of your server and reach it, and then try the external (WAN) IP address, you are OK. Anyone else that accesses your site will be able to access it with your "myname.subsonic.org" address with no problems.
gurutech
