Nothing will load after log in
Postby aforesterj » Sun Jan 11, 2015 7:17 pm
I've been having this issue for the last few weeks...
Any help would be great!
Thanks.
Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; out of memory; nested exception is java.sql.SQLException: out of memory
Java version Oracle Corporation 1.8.0_25
Server jetty-6.1.x
Memory Used 20 of 84 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where path=?]; out of memory; nested exception is java.sql.SQLException: out of memory
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:120)
at net.sourceforge.subsonic.dao.MediaFileDao.getMediaFile(MediaFileDao.java:62)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:103)
at net.sourceforge.subsonic.service.MusicIndexService.createSortableArtists(MusicIndexService.java:145)
at net.sourceforge.subsonic.service.MusicIndexService.getIndexedArtists(MusicIndexService.java:61)
at net.sourceforge.subsonic.controller.LeftController.getMusicFolderContent(LeftController.java:220)
at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:142)
at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:227)
at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:626)
Caused by: java.sql.SQLException: out of memory
... 66 more
aforesterj
Re: Nothing will load after log in
Postby norton163 » Wed Jan 21, 2015 4:28 pm
hi...did you get a fix? I have the same issue
norton163
