Subsonic can't find LAME?
Postby pberch » Thu Jan 22, 2009 10:03 pm
I'm running Subsonic under tomcat, and can successfully stream .mp3 files, but encounter a problem when attempting to transcode from .mp4-->mp3. I think this is due to Subsonic not being able to use LAME; I still get the
"Notice: LAME does not seem to be installed.
Click Help button for more information."
message, even though I do have LAME installed. I have successfully transcoded the test files that came with LAME via the command line, and have access to LAME from any directory, so far as I can tell...
The subsonic log shows faad moving through its processes, but I only get one line for LAME before the conversion abruptly stops without explanation.
Any suggestions are appreciated!
pberch
Postby kopf » Fri Jan 23, 2009 11:24 pm
make sure the directory that lame is in is also in the system path:
http://www.computerhope.com/issues/ch000549.htm
kopf
