iSub doesn't work on LAN but everywhere else YES.
Postby toerag » Tue Jan 20, 2015 9:55 pm
I've install subsonic server on OMV -- works great locally and over the internet via web browser.
Installed iSub on phone and ipad - it also works great over the internet, and over WiFi -- but ONLY from another LAN - from which the subsonic server is on. I've tried local IP & port addresses but nothing within the iSub app. I can connect with the iPhone using Safari & Chrome browser but NOT with the iSub App??? unless I shut off Wifi while in my own network's Wifi, using just cellular data to connect.
what's not set right? EVERYTHING works fine from everywhere but from home on my own Wifi.
toerag
Re: iSub doesn't work on LAN but everywhere else YES.
Postby seanpkeown » Thu Jan 22, 2015 6:40 pm
If you're connecting via your WAN IP address then check to make sure that your home router doesn't have a feature called Filter WAN NAT Redirection turned on.
seanpkeown
Users browsing this forum: No registered users and 182 guests
