Error 500 - ConflictInMappingEntry when upgrading to 5.1
Postby visserj » Fri Jan 23, 2015 9:28 am
Hi - I have just upgraded Subsonic on Ubuntu 14.1 using the .deb package installer (I also upgraded java to openjdk-7-jre).
I have Subsonic running on port 80.
When I browse to subsonic, I get the directory list. And checking in /var/subsonic/subsonic.log I can see the following error message:
java.lang.Exception: 500 Internal Server Error: Error: ConflictInMappingEntry (HTTP response was: 500 Internal Server Error)
        at net.sourceforge.subsonic.service.upnp.ClingRouter.addPortMappingImpl(ClingRouter.java:116)
        at net.sourceforge.subsonic.service.upnp.ClingRouter.addPortMapping(ClingRouter.java:89)
        at net.sourceforge.subsonic.service.NetworkService$PortForwardingTask.execute(NetworkService.java:149)
        at net.sourceforge.subsonic.service.NetworkService$Task.run(NetworkService.java:306)
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
        at java.util.concurrent.FutureTask$Sync.innerRunAndReset(FutureTask.java:351)
        at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:178)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:165)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:267)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1146)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
        at java.lang.Thread.run(Thread.java:701)
Does anyone have any ideas how to fix this? Is there a file I can edit to correct the "mapping entry"?
Any help would be appreciated.
Kind Regards
Jonathan
visserj
Users browsing this forum: Google [Bot] and 26 guests
