Similar artists and radio feature in Subsonic 5.1
Postby kayvee » Wed Jan 28, 2015 3:00 am
Just installed Subsonic 5.1 and noticed these new features in the changelog:
New: Show artist image and bio.
New: Show similar artists, with radio feature.
My question is - where are they? I could not seem to locate the feature to find similar artists or to play a radio. I have my last.fm credentials entered and am able to scrobble to last.fm just fine. Does this feature require last.fm premium subscription?
kayvee
Re: Similar artists and radio feature in Subsonic 5.1
Postby titooo » Wed Jan 28, 2015 10:53 am
I also can't see this and non of my artist is showing any artist image.
Could anyone provide a quick guide step by step guide on how to have those features working for new users ?
titooo
Postby mockingbrd » Wed Jan 28, 2015 1:09 pm
If I understand correctly, the Last.FM integration matches artists' info based on folder names, not ID3 tags, which is unfortunate.
So basically if your artist folders are named:
Doors, The = No info from Last.FM
The Doors = Last.FM info will be displayed
Jackson, Michael = No info from Last.FM
Michael Jackson = Last.FM info will be displayed
I posted about the issue here but have not received any replies: viewtopic.php?f=2&t=15168
mockingbrd
Postby titooo » Wed Jan 28, 2015 1:54 pm
titooo wrote:I also can't see this and non of my artist is showing any artist image.
In regards to my question.
I noticed that the artist image only appears from the subsonic website.
Edit: the new dsub update also shows the artist image once you have clicked on the artist name
titooo
Postby kayvee » Wed Jan 28, 2015 4:33 pm
So this works only if I have my entire library arranged in folders <Artist>/<Album>/<Track.mp3>?
It is very unfortunate if that is the case because I have my entire library arranged as <Album>/<Track.mp3> right now.
kayvee
Postby daneren2005 » Wed Jan 28, 2015 5:06 pm
kayvee wrote:So this works only if I have my entire library arranged in folders <Artist>/<Album>/<Track.mp3>?
Well then where would Subsonic even try to display the artist info since you go directly into the album.
Postby kayvee » Wed Jan 28, 2015 5:18 pm
I thought it would be based on id3 tags. I wasn't sure where the artist info will be displayed to start with. That was the reason for this question to start with. Anyway, I am more interested in similar artists radio than info about artists. After I posted my last response I looked further and found out Subsonic getting started page clearly says that the folder structure should be in the artist/album/track manner. I have been using subsonic since 2.x days and since it always worked fine with the way I have it I never bothered to check the getting started guide... Now I have a weekend project to reorganize my library.
kayvee
Users browsing this forum: No registered users and 41 guests
