Can't see Left-Hand side pane
Postby quimbo » Fri Feb 13, 2015 6:12 pm
veresion 5.1. Left hand side now gives me what is below. The right-hand side renders well. i think this started after I updated java
Info icon
The website cannot display the page
HTTP 500
Most likely causes:
•The website is under maintenance.
•The website has a programming error.
What you can try:
Refresh the page.
Go back to the previous page.
More information More information
This error (HTTP 500 Internal Server Error) means that the website you are visiting had a server problem which prevented the webpage from displaying.
For more information about HTTP errors, see Help.
quimbo
Re: Can't see Left-Hand side pane
Postby quimbo » Sat Feb 21, 2015 5:30 am
Solved. When I tried to connect from my android it displayed an error message about not being able to fine C:\Program Files (x86)\Java\jre1.8.0_25\lib\resources.jar Copied this file from another pc and now everything displays. I caused this after a Java update and then uninstalling older versions.
quimbo
