Internal Error Report
Postby sdgenxr » Mon Feb 16, 2015 10:58 pm
I recently opened up the web interface and found an error report table. It does not appear to have any affect on streaming ability, just wanted to see if it's something I should be aware of?
Problem Description: Subsonic encountered an internal error.
Troubleshooting Steps: None
Playback Application and version: N/A
Subsonic Version: 5.0 (build 4100) – September 21, 2014
Server Version: jetty-6.1.x, java 1.7.0_65, FreeBSD (42.8 MB / 135.5 MB)
Hardware Platform: FreeBSD running on a ASRock C2750D4I motherboard with 16GB Crucial ECC memory running FreeNAS
Java Memory Limit: N/A
Problem Filename: N/A
Last ten log file lines:
[2/16/15 11:42:49 AM PST]    INFO   DaoHelper   Checking database schema.
[2/16/15 11:42:57 AM PST]    INFO   DaoHelper   Done checking database schema.
[2/16/15 11:42:58 AM PST]    INFO   VersionService   Resolved local Subsonic version to: 5.0
[2/16/15 11:42:59 AM PST]    INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Tue Feb 17 03:00:00 PST 2015
[2/16/15 11:42:59 AM PST]    INFO   UPnPService   Starting UPnP service...
[2/16/15 11:42:59 AM PST]    INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Mon Feb 16 11:47:59 PST 2015
[2/16/15 11:42:59 AM PST]    INFO   UPnPService   Enabling UPnP/DLNA media server
[2/16/15 11:42:59 AM PST]    INFO   UPnPService   Starting UPnP service - Done!
[2/16/15 11:43:09 AM PST]    WARN   NetworkService   No UPnP router found.
[2/16/15 11:47:59 AM PST]    INFO   PodcastService   Starting scheduled Podcast refresh.
Error Report:
Exception:    org.springframework.jdbc.BadSqlGrammarException
Message:    PreparedStatementCallback; bad SQL grammar [select id, name, type, username, ip_address, auto_control_enabled, last_seen, cover_art_scheme, transcode_scheme, dynamic_ip, technology, client_id from player where id=?]; nested exception is java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: ""
Java version:    Oracle Corporation 1.7.0_65
Operating system:    FreeBSD 9.1-RELEASE
Server:    jetty-6.1.x
Memory    Used: 37 of 143 MB
Stack trace:    org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [select id, name, type, username, ip_address, auto_control_enabled, last_seen, cover_art_scheme, transcode_scheme, dynamic_ip, technology, client_id from player where id=?]; nested exception is java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: ""
at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:97)
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:83)
at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:120)
at net.sourceforge.subsonic.dao.PlayerDao.getPlayerById(PlayerDao.java:88)
at net.sourceforge.subsonic.service.PlayerService.getPlayerById(PlayerService.java:175)
at net.sourceforge.subsonic.service.PlayerService.getPlayer(PlayerService.java:94)
at net.sourceforge.subsonic.service.PlayerService.getPlayer(PlayerService.java:64)
at net.sourceforge.subsonic.controller.PlayQueueController.handleRequestInternal(PlayQueueController.java:53)
at net.sourceforge.subsonic.filter.ResponseHeaderFilter.doFilter(ResponseHeaderFilter.java:47)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:442) Caused by: java.sql.SQLException: Wrong data type: java.lang.NumberFormatException: For input string: ""
at org.hsqldb.jdbc.jdbcPreparedStatement.setParameter(Unknown Source)
at org.hsqldb.jdbc.jdbcPreparedStatement.setString(Unknown Source)
at org.springframework.jdbc.core.StatementCreatorUtils.setValue(StatementCreatorUtils.java:335)
at org.springframework.jdbc.core.StatementCreatorUtils.setParameterValueInternal(StatementCreatorUtils.java:217)
at org.springframework.jdbc.core.StatementCreatorUtils.setParameterValue(StatementCreatorUtils.java:145)
at org.springframework.jdbc.core.ArgPreparedStatementSetter.setValues(ArgPreparedStatementSetter.java:51)
at org.springframework.jdbc.core.JdbcTemplate$1.doInPreparedStatement(JdbcTemplate.java:646)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:591) ... 66 more
sdgenxr
