Error when granting access to music folder
Postby NanoIron » Tue Feb 17, 2015 10:54 am
Hi all
Running
5.2.beta1 (build 4393)
jetty-6.1.x, java 1.8.0_31, Windows 8
Had a smooth running subsonic system running for a year. On the weekend java errors appeared, so I decided to uninstall subsonic and java, install from scratch leaving everything at default values.
Scanned the local hard drive e:\ for music as per usual, all found.
Now... ticking the box to allow admin access to e:\music - save. BANG, java error as per below.
Created another user, same thing, completely reproducible.
Threw data base out, tried again. Same.
Ideas anyone?
Error log:
62495 [btpool0-3] ERROR org.mortbay.log - Nested in org.springframework.web.util.NestedServletException: Request processing failed; nested exception is java.lang.ClassCastException: java.lang.String cannot be cast to java.lang.Integer:
   at net.sourceforge.subsonic.dao.MusicFolderDao.setMusicFoldersForUser(MusicFolderDao.java:96)
   at net.sourceforge.subsonic.service.SettingsService.setMusicFoldersForUser(SettingsService.java:1106)
   at net.sourceforge.subsonic.controller.UserSettingsController.updateUser(UserSettingsController.java:159)
   at net.sourceforge.subsonic.controller.UserSettingsController.doSubmitAction(UserSettingsController.java:113)
   at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:443)
   at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:409)
   at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:381)
   at org.springframework.web.servlet.mvc.SimpleFormController.processFormSubmission(SimpleFormController.java:267)
   at org.springframework.web.servlet.mvc.AbstractFormController.handleRequestInternal(AbstractFormController.java:265)
   at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
   at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
   at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:844)
   at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:644)
NanoIron
Re: Error when granting access to music folder
Postby jamburglar » Mon Feb 23, 2015 3:00 am
Having the same issue.
Exception   java.lang.ClassCastException
Message   java.lang.String cannot be cast to java.lang.Integer
Java version   Oracle Corporation 1.8.0_31
Operating system   Windows 7 6.1
Server   jetty-6.1.x
Memory   Used 87 of 141 MB
Stack trace   java.lang.ClassCastException: java.lang.String cannot be cast to java.lang.Integer
   at net.sourceforge.subsonic.controller.UserSettingsController.createUser(UserSettingsController.java:126)
   at net.sourceforge.subsonic.controller.UserSettingsController.doSubmitAction(UserSettingsController.java:111)
   at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:227)
   at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:626)
jamburglar
Users browsing this forum: Google [Bot] and 28 guests
