FLAC Transcoding no longer working
Postby tmwsiy » Fri Feb 20, 2015 4:04 pm
Not sure if it is a result of upgrading to 5.2beta1 or not but I can no longer play FLAC.
It just won't play on either mobile app, web, or Sonos.
I have not touched the default transcoding settings.
I have ensured that the transcoder is still installed properly and the settings are correct.
The red box from log shows where I tried to play a track.
tmwsiy
Re: FLAC Transcoding no longer working
Postby evvywevvy » Sat Mar 07, 2015 11:38 pm
I'm having this same issue on the 5.2.1 release. I'm running the WAR version on FreeBSD 10.1. The default transcoding entry includes m4a files, and they are playing fine.
evvywevvy
