Subsonic 5.2.beta1 - Java failure after saving user-settings
Postby Mosquitoz » Sat Feb 21, 2015 2:55 pm
*original post is adjusted on 22 feb 2015
Hello Sindre,
First I use Subsonic and iSub-app iPhone based on Subsonic's engine & databaseserver for many years. The best music-server there is IMO ! Chapeaux1
I have read you have fixed the java-problem after saving changed user-settings with the version 5.1.beta2.
You told it happens only with Java 8.
See : http://forum.subsonic.org/forum/viewtopic.php?f=4&t=15086&start=15 somewhere in the middle :D
I use the WAR-version 5.2.beta1 for my QNAP-NAS TS-439 Pro II+, x86-based (Intel)
Java JRE v8.6 (2014/12/05 is installed on this machine.
Operating system Linux 3.4.6
Stil the problem is there : java.lang.String cannot be cast to java.lang.Integer
Exception java.lang.ClassCastException
Message java.lang.String cannot be cast to java.lang.Integer
Java version Oracle Corporation 1.8.0
Server jetty-6.1.x
Memory Used 69 of 96 MB
Stack trace java.lang.ClassCastException: java.lang.String cannot be cast to java.lang.Integer
at net.sourceforge.subsonic.dao.MusicFolderDao.setMusicFoldersForUser(MusicFolderDao.java:96)
at net.sourceforge.subsonic.service.SettingsService.setMusicFoldersForUser(SettingsService.java:1106)
at net.sourceforge.subsonic.controller.UserSettingsController.updateUser(UserSettingsController.java:159)
at net.sourceforge.subsonic.controller.UserSettingsController.doSubmitAction(UserSettingsController.java:113)
etc. etc.
Can you take a look at it?
Thanx in advance !
Greetz
Tom
Mosquitoz
Re: Subsonic 5.2.beta1 - Java failure after saving user-sett
Postby Toedels » Sun Feb 22, 2015 1:57 pm
Same her, running 5.2 beta 1.
Added some folders under admin, but only the last is allowed access.
When i want to permit access other folders, i get the error.
Is downgrading Java an temp solution?
Toedels
Postby chali » Mon Feb 23, 2015 12:10 am
Same for me, running on windows x64
/Regards
chali
Postby tumtum1088 » Tue Feb 24, 2015 4:23 am
Getting the same error here, windows x64 java 8 update 31 subsonic 5.2.beta1
at net.sourceforge.subsonic.controller.UserSettingsController.createUser(UserSettingsController.java:126)
at net.sourceforge.subsonic.controller.UserSettingsController.doSubmitAction(UserSettingsController.java:111)
at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:443)
at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:409)
at org.springframework.web.servlet.mvc.SimpleFormController.onSubmit(SimpleFormController.java:381)
at org.springframework.web.servlet.mvc.SimpleFormController.processFormSubmission(SimpleFormController.java:267)
at org.springframework.web.servlet.mvc.AbstractFormController.handleRequestInternal(AbstractFormController.java:265)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:844)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:644)
tumtum1088
Postby dorfbewohner » Tue Feb 24, 2015 8:02 am
same for me:
I can`t give folder access to any else user than admin, but can add all right like user is allowed to....
without any issues.
In an act of Desperation I have added the user / pass same as in subsonic to Windows ADUC and to the QNAP where the Folders are located, but mounted via Windows, without success.
Java version Oracle Corporation 1.8.0_31
Operating system Windows Server 2008 R2 6.1
Server jetty-6.1.x
Memory Used 85 of 145 MB
regards,
Dorfbewohner
dorfbewohner
Postby Mosquitoz » Wed Feb 25, 2015 8:55 am
Problem solved with version Subsonic 5.2 !
Thanx for the fast update SIndre! Amazing work and keep going to make Subsonic better and better! :lol: :D
Greetz,
Tom
Mosquitoz
