Crash after upgrade from 5.1
Postby KingOS » Wed Feb 25, 2015 8:17 am
After upgrading from 5.1 to 5.2
Exception   org.springframework.jdbc.BadSqlGrammarException
Message   PreparedStatementCallback; bad SQL grammar [select music_folder.id,music_folder.path,music_folder.name,music_folder.enabled,music_folder.changed from music_folder, music_folder_user where music_folder.id = music_folder_user.music_folder_id and music_folder_user.username = ?]; nested exception is java.sql.SQLException: Table not found in statement [select music_folder.id,music_folder.path,music_folder.name,music_folder.enabled,music_folder.changed from music_folder, music_folder_user where music_folder.id = music_folder_user.music_folder_id and music_folder_user.username = ?]
Java version   Oracle Corporation 1.7.0_75
Operating system   Linux 3.13.0-44-generic
Server   jetty-6.1.x
Memory   Used 66 of 123 MB
Stack trace   org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [select music_folder.id,music_folder.path,music_folder.name,music_folder.enabled,music_folder.changed from music_folder, music_folder_user where music_folder.id = music_folder_user.music_folder_id and music_folder_user.username = ?]; nested exception is java.sql.SQLException: Table not found in statement [select music_folder.id,music_folder.path,music_folder.name,music_folder.enabled,music_folder.changed from music_folder, music_folder_user where music_folder.id = music_folder_user.music_folder_id and music_folder_user.username = ?]
   at org.springframework.jdbc.support.SQLErrorCodeSQLExceptionTranslator.doTranslate(SQLErrorCodeSQLExceptionTranslator.java:220)
   at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:97)
   at net.sourceforge.subsonic.dao.MusicFolderDao.getMusicFoldersForUser(MusicFolderDao.java:91)
   at net.sourceforge.subsonic.service.SettingsService.getMusicFoldersForUser(SettingsService.java:1098)
   at net.sourceforge.subsonic.service.SettingsService.getMusicFoldersForUser(SettingsService.java:1057)
   at net.sourceforge.subsonic.service.SettingsService.getSelectedMusicFolder(SettingsService.java:1084)
   at net.sourceforge.subsonic.controller.HomeController.handleRequestInternal(HomeController.java:77)
   at net.sourceforge.subsonic.filter.ResponseHeaderFilter.doFilter(ResponseHeaderFilter.java:47)
Caused by: java.sql.SQLException: Table not found in statement [select music_folder.id,music_folder.path,music_folder.name,music_folder.enabled,music_folder.changed from music_folder, music_folder_user where music_folder.id = music_folder_user.music_folder_id and music_folder_user.username = ?]
   at org.hsqldb.jdbc.jdbcPreparedStatement.(Unknown Source)
   at org.hsqldb.jdbc.jdbcConnection.prepareStatement(Unknown Source)
   at org.springframework.jdbc.core.JdbcTemplate$SimplePreparedStatementCreator.createPreparedStatement(JdbcTemplate.java:1322)
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:585)
   ... 65 more
Downgrade to 5.1 resolves the issue
I used deb's to install and I'm running on headless Ubuntu Server 14.04.1 with a premium subsonic licence
Let me know if more info is needed...
KingOS
Users browsing this forum: Google [Bot] and 28 guests
