Specific Songs Stop Playing After One Second
Postby jjgittes » Fri Feb 27, 2015 2:57 pm
Hi all,
I have noticed that on more than one song, if I start playing it through the web interface it will stop after one second. If I play the actual file stored on the server through a media player, it's fine, so the file isn't corrupted. If I skip forward in the song, it will play from that part but only for one second.
It also seems to be album-wide. So the first song I discovered it on - the entire album has the issue. Then I found another, from another album, and its entire album had the issue too.
Any reason why this happens, and is there a way to fix the situation?
Many thanks in advance.
jjgittes
