Cannot access server using mobile network... WiFi no problem
Postby sjgoldman » Sat Feb 28, 2015 7:52 pm
I've used Subsonic for quite some time and have been very satisfied. However, after upgrading to V5.2 something has gone wrong. When my mobile phone (Sam. Galaxy 3) is connected to my Wi-Fi network everything works fine, but when connected to my mobile network the apps (Subsonic Music Streamer 4.4 or Dsub) say they cannot find the network. I use my admin user settings. There has never been a problem before, and try as I might, I cannot seem to figure out what's wrong. The log does not help... there is no indication of an attempt to log on. Any suggestions?
Steve
sjgoldman
Re: Cannot access server using mobile network... WiFi no pro
Postby IdiotProof » Sun Mar 01, 2015 8:16 am
Check in your box/router if your 4040 or 4443 port is corectly forwarded (for TCP and UDP Protocol), if only forward ssl port 4443 be sure to use https://my.adress.ip:4443 to log in (easy myregistername.subsonic.org doesn't work anymore)
IdiotProof
Users browsing this forum: No registered users and 153 guests
