Jukebox, mp3 vbr, avi playback issues
Postby honeybadger » Sat Mar 07, 2015 10:43 am
I have encountered some issues after latest update to the 5.2.1 version. (using raspberrypi)
- The Jukebox doesn't work, and just do nothing. The log file shows this:
[3/7/15 11:21:49 AM CET] INFO TranscodeInputStream Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [0] [-i] [directory/song.mp3] [-map] [0:0] [-v] [0] [-f] [s16be] [-]
[3/7/15 11:21:49 AM CET] INFO InputStreamReaderThread (/var/subsonic/transcode/ffmpeg) /var/subsonic/transcode/ffmpeg: 1: /var/subsonic/transcode/ffmpeg: Syntax error: "(" unexpected
[3/7/15 11:21:49 AM CET] INFO JukeboxService user starting jukebox for "directory/song.mp3"
[3/7/15 11:21:49 AM CET] INFO JukeboxService user stopping jukebox for "directory/song.mp3"
- mp3 vbr files and avi files have in the log the same thing with unexpected bracket thing.
Could you please help? It's really sad, that after update these key features does not work :(
honeybadger
Re: Jukebox, mp3 vbr, avi playback issues
Postby otis_bartleh » Sun Mar 15, 2015 6:09 pm
Jukebox isn't working for me either... It just won't play, and isn't even giving any info in the log...
Casting to XBMC isn't working either....
Jukebox used to work fine for me on my old phone and older Subsonic server version...
otis_bartleh
Postby honeybadger » Sun Mar 22, 2015 12:53 pm
Ok, I have solved it just by replacing ffmpeg in transcode directory, because it didn't replace itself while upgrading.
$ sudo rm /var/subsonic/transcode/ffmpeg
$ sudo ln -s /usr/bin/ffmpeg /var/subsonic/transcode/ffmpeg
honeybadger
Postby marcosab1991 » Wed Mar 25, 2015 8:10 pm
same problem here but everyone seems to ignore it...
i did what you did and stopped working no good
marcosab1991
