Album Artwork being 'funny' since 5.2.1?
Postby acroyear » Sun Mar 08, 2015 1:52 am
My artwork was coming up fine in 5.1.
Starting today, with 5.2.1, the artwork looks generally fine on the main web app, but *some* artwork won't appear in any other context correctly. The server serves up the default two-color + text default artwork. This includes the right side "currently playing" and my SubFire client.
Any ideas? Nothing else in my env has changed.
And again, it isn't *all* artwork, but certain folders seem more affected than others.
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Re: Album Artwork being 'funny' since 5.2.1?
Postby acroyear » Sun Mar 08, 2015 2:01 am
In addition, any artwork that is having this problem will not be able to "zoom" in the main web app.
If I go through the process of replacing the artwork, it will work fine from that point on. I'm not sure how wide-spread this is on my system.
Currently running a full media scan to see if it helps.
Joe Shelby
acroyear
Postby acroyear » Sun Mar 08, 2015 3:47 pm
As I keep digging around, this seems to just be isolated to one particular subset of folders which I think may have gotten mildly corrupted as I moved them from one hard drive to another as the controller on the first drive started to go. That was a while ago, but 5.2 seems 'sensitive' to the changes that 5.1 wasn't. In any case, if I just go through folder by folder and replace the cover art, things seem to work again without issue.
Joe Shelby
acroyear
Postby deejay2302 » Fri May 08, 2015 5:21 pm
U have fixed this problem? I have the same. I have only the standard cover arts and can not change it. :-/
21.681 Artists
58.141 Albums
674.091 Songs
5072,14 GB (~ 49.341 Hours)
deejay2302
