custom "subsonic.org" address not updating correctly
Postby p4xel » Sun Mar 08, 2015 12:53 pm
Problem Description:
Subsonic premium account. I have been using it for a while and I have my custom dyndns.org address. All works fine, but if I want to share anything it is more convenient to enable custom domain name.
Problem 1: When I enable https connection
SUBSONIC_ARGS="--port=4040 --https-port=4041 --max-memory=512 --home=/opt/apps/subsonic"
the response is "Status: xxxx.subsonic.org responded successfully, but could not authenticate it."
My ports are forwarded correctly and I can connect on port 4041 with no issues. When I remove "--https-port" it updates with no issues.
Problem 2: when trying to connect from home (LAN) it resolves to wrong internal address "http://192.168.122.1:4040/"
Subsonic Version: 5.2.1 (build 4428) – March 4, 2015
Server Version: jetty-6.1.x, java 1.7.0_75
Hardware Platform: Ubuntu Server 14.10
Java Memory Limit: 512MB
Last ten log file lines:
[2015-03-08 12:41:43,538] INFO PlayerDao - Created player 14.
[2015-03-08 12:41:43,710] INFO VersionService - Resolved latest Subsonic final version to: 5.2.1
[2015-03-08 12:41:43,711] INFO VersionService - Resolved latest Subsonic beta version to: 5.2.beta1
[2015-03-08 12:42:27,245] INFO NetworkService - Deleted port mapping for port 4040
[2015-03-08 12:42:27,279] INFO NetworkService - Deleted port mapping for port 4041
[2015-03-08 12:46:26,141] INFO PodcastService - Starting scheduled Podcast refresh.
[2015-03-08 12:46:26,143] INFO PodcastService - Completed scheduled Podcast refresh.
[2015-03-08 12:49:35,553] INFO NetworkService - Deleted port mapping for port 4040
[2015-03-08 12:49:35,675] INFO NetworkService - Deleted port mapping for port 4041
p4xel
