Subsonic Error
Subsonic Error
Postby andreasdevig » Sun Mar 08, 2015 2:30 pm
Hello. I have another problem with iSub/Subsonic. When I log into Subsonic this is the message I get on the left side of the computer screen. Can you please help me?? Thanks. Message I get is as follows...
"Error
Exception org.springframework.jdbc.BadSqlGrammarException
Message PreparedStatementCallback; bad SQL grammar [select music_folder.id,music_folder.path,music_folder.name,music_folder.enabled,music_folder.changed from music_folder, music_folder_user where music_folder.id = music_folder_user.music_folder_id and music_folder_user.username = ?]; nested exception is java.sql.SQLException: Table not found in statement [select music_folder.id,music_folder.path,music_folder.name,music_folder.enabled,music_folder.changed from music_folder, music_folder_user where music_folder.id = music_folder_user.music_folder_id and music_folder_user.username = ?]
Java version Oracle Corporation 1.8.0_25
Operating system Windows 8 6.2
Server jetty-6.1.x
Memory Used 57 of 125 MB
Stack trace org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [select music_folder.id,music_folder.path,music_folder.name,music_folder.enabled,music_folder.changed from music_folder, music_folder_user where music_folder.id = music_folder_user.music_folder_id and music_folder_user.username = ?]; nested exception is java.sql.SQLException: Table not found in statement [select music_folder.id,music_folder.path,music_folder.name,music_folder.enabled,music_folder.changed from music_folder, music_folder_user where music_folder.id = music_folder_user.music_folder_id and music_folder_user.username = ?]
at org.springframework.jdbc.support.SQLErrorCodeSQLExceptionTranslator.doTranslate(SQLErrorCodeSQLExceptionTranslator.java:220)
at net.sourceforge.subsonic.dao.AbstractDao.query(AbstractDao.java:97)
at net.sourceforge.subsonic.dao.MusicFolderDao.getMusicFoldersForUser(MusicFolderDao.java:91)
at net.sourceforge.subsonic.service.SettingsService.getMusicFoldersForUser(SettingsService.java:1098)
at net.sourceforge.subsonic.service.SettingsService.getMusicFoldersForUser(SettingsService.java:1057)
at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:126)
at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:227)
at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:626)
Caused by: java.sql.SQLException: Table not found in statement [select music_folder.id,music_folder.path,music_folder.name,music_folder.enabled,music_folder.changed from music_folder, music_folder_user where music_folder.id = music_folder_user.music_folder_id and music_folder_user.username = ?]
at org.hsqldb.jdbc.jdbcPreparedStatement.(Unknown Source)
at org.hsqldb.jdbc.jdbcConnection.prepareStatement(Unknown Source)
at org.springframework.jdbc.core.JdbcTemplate$SimplePreparedStatementCreator.createPreparedStatement(JdbcTemplate.java:1322)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:585)
... 63 more
andreasdevig
Re: Subsonic Error
Postby alphawave7 » Sun Mar 08, 2015 6:06 pm
Try shutting off SS service, and update Java (I believe current update number is 40?). Once installed, restart Subsonic service, nav to Settings, DELETE the path to your media, hit save, exit out and stop SS service again. Restart SS service, nav to Media folders in Settings and add you path. It should begin re-indexing your files. Cheers!
Re: Subsonic Error
Postby andreasdevig » Sun Mar 08, 2015 9:55 pm
Didn't work. I assume you mean the settings and media folders on the subsonic web page, and not on the subsonic control panel (subsonic windows icon)...
andreasdevig
Re: Subsonic Error
Postby Xylure » Wed Mar 11, 2015 8:32 pm
Same error for me.
I don't know what to do.
Xylure
Re: Subsonic Error
Postby andreasdevig » Thu Jul 09, 2015 5:06 pm
Xylure wrote:Same error for me.
Did you try to delete and reinstall it?
andreasdevig
