Issue using Jetty 6.1.15-rc3 + Subsonic 3.6
Postby seitz » Tue Feb 03, 2009 10:14 pm
When I click on home I get the following in the middle tab. When I click on settings I get the same. Any help would be appreciated!
Diagnostics below:
Exception org.apache.jasper.JasperException
Message /WEB-INF/jsp/home.jsp(23,4) PWC6340: According to the TLD, rtexprvalue is true, and deferred-value is specified for the attribute items of the tag handler org.apache.taglibs.standard.tag.rt.core.ForTokensTag, but the argument for the setter method is not a java.lang.Object
Java version Sun Microsystems Inc. 1.6.0_12
Operating system Linux 2.6.26-1-amd64
Server jetty/6.1.15.rc3
Memory Used 191 of 306 MB
Stack trace org.apache.jasper.JasperException: /WEB-INF/jsp/home.jsp(23,4) PWC6340: According to the TLD, rtexprvalue is true, and deferred-value is specified for the attribute items of the tag handler org.apache.taglibs.standard.tag.rt.core.ForTokensTag, but the argument for the setter method is not a java.lang.Object at org.apache.jasper.compiler.DefaultErrorHandler.jspError(DefaultErrorHandler.java:78) at org.apache.jasper.compiler.ErrorDispatcher.dispatch(ErrorDispatcher.java:373) at org.apache.jasper.compiler.ErrorDispatcher.jspError(ErrorDispatcher.java:201) at org.apache.jasper.compiler.Validator$ValidateVisitor.checkSetter(Validator.java:1059) at org.apache.jasper.compiler.Validator$ValidateVisitor.checkXmlAttributes(Validator.java:1128) at org.apache.jasper.compiler.Validator$ValidateVisitor.visit(Validator.java:850) at org.apache.jasper.compiler.Node$CustomTag.accept(Node.java:1501) at org.apache.jasper.compiler.Node$Nodes.visit(Node.java:2291) at org.apache.jasper.compiler.Node$Visitor.visitBody(Node.java:2341) at org.apache.jasper.compiler.Node$Visitor.visit(Node.java:2347) at org.apache.jasper.compiler.Node$Root.accept(Node.java:498) at org.apache.jasper.compiler.Node$Nodes.visit(Node.java:2291) at org.apache.jasper.compiler.Validator.validate(Validator.java:1853) at org.apache.jasper.compiler.Compiler.generateJava(Compiler.java:210) at org.apache.jasper.compiler.Compiler.compile(Compiler.java:435) at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:608) at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:360) at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:486) at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:380) at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:502) at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:363) at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216) at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181) at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:766) at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:417) at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:334) at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:126) at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:167) at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:239) at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1158) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:900) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:808) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:476) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:431) at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:502) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1124) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107) at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:166) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:173) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249) at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275) at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149) at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1115) at net.sourceforge.subsonic.filter.ResponseHeaderFilter.doFilter(ResponseHeaderFilter.java:47) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1115) at net.sourceforge.subsonic.filter.RequestEncodingFilter.doFilter(RequestEncodingFilter.java:43) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1115) at net.sourceforge.subsonic.filter.ParameterDecodingFilter.doFilter(ParameterDecodingFilter.java:54) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1115) at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:54) at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1115) at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:361) at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216) at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181) at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:766) at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:417) at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:230) at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114) at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152) at org.mortbay.jetty.Server.handle(Server.java:324) at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:535) at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:865) at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:538) at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:212) at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404) at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:228) at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:636) at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:522)
seitz
Additional Info
Postby seitz » Tue Feb 03, 2009 10:28 pm
To note it also happens with the following JVM:
Sun Microsystems Inc. 1.5.0_17
seitz
Offending code
Postby seitz » Wed Feb 04, 2009 5:42 am
I can't find anything wrong with this code so I'll just have to wait for someone smarter than myself here ;) *poke* author!
<%@ page language="java" contentType="text/html; charset=utf-8" pageEncoding="iso-8859-1" %>
<%@ include file="include.jsp" %>
<c:set var="categories" value="${param.restricted ? 'personal password player' : 'musicFolder general advanced personal user player transcoding internetRadio podcast search'}"/>
<h1>
<img src="<spring:theme code="settingsImage"/>" alt=""/>
<fmt:message key="settingsheader.title"/>
</h1>
<h2>
***** ANGRY CODE BELOW ****
<c:forTokens items="${categories}" delims=" " var="cat" varStatus="loopStatus">
<c:if test="${loopStatus.count > 1}">&nbsp;|&nbsp;</c:if>
<c:url var="url" value="${cat}Settings.view?"/>
<c:choose>
<c:when test="${param.cat eq cat}">
<span class="headerSelected"><fmt:message key="settingsheader.${cat}"/></span>
</c:when>
<c:otherwise>
<a href="${url}"><fmt:message key="settingsheader.${cat}"/></a>
</c:otherwise>
</c:choose>
</c:forTokens>
</h2>
<p/>
seitz
Postby seitz » Wed Feb 04, 2009 6:14 pm
Tap tap tap... is this thing on?
seitz
Postby seitz » Thu Feb 05, 2009 6:38 am
Nevermind, I went to apache2 + mod_gnutls + mod_jk + Tomcat.
seitz
Re: Issue using Jetty 6.1.15-rc3 + Subsonic 3.6
Postby NoZomIBK » Fri Sep 07, 2012 8:09 pm
For everyone with this error, look at my post here
NoZomIBK
