Trouble with Transcoding
Postby StanSmith » Fri Mar 27, 2015 2:39 pm
Problem Description: I am having trouble getting Subsonic to transcode my media with ffmpeg. Most likely need to recompile from the source code but I am having trouble getting any clear guidance for this on FreeBSD. My subsonic server is installed inside a jail on my Nas4Free server. My first erro that lead me to beleive it was my version of ffmpeg installed was this: (/var/subsonic/transcode/ffmpeg) Unrecognized option 'ba'
Troubleshooting Steps: I have gone through
Playback Application and version: I've been using the webbased player and an android app called ultrasonic
Subsonic Version: 5.2.1 (build 4427) – March 4, 2015
Server Version: jetty-6.1.x, java 1.7.0_25, FreeBSD (82.1 MB / 100.9 MB)
Hardware Platform: Nas4Free 9.3.0.2 - Nayla (revision 1349)
Problem Filename: ffmpeg transcoding
Output from ffmpeg -i: (If you open a command prompt and type 'ffmpeg -i <filename>' what is the output? Ideally put this in a "code" block)
Last ten log file lines:
[2015-03-26 20:35:44,525] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) ffmpeg version 0.7.15, Copyright (c) 2000-2013 the FFmpeg developers
[2015-03-26 20:35:44,525] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   built on Aug 12 2013 11:01:01 with gcc 4.2.1 20070831 patched [FreeBSD]
[2015-03-26 20:35:44,525] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   configuration: --prefix=/usr/local --mandir=/usr/local/man --enable-shared --enable-gpl --enable-postproc --enable-avfilter --enable-pthreads --enable-memalign-hack --enable-runtime-cpudetect --cc=cc --extra-cflags='-I/usr/local/include/vorbis -I/usr/local/include' --extra-ldflags='-L/usr/local/lib ' --extra-libs=-pthread --disable-debug --disable-libaacplus --disable-indev=alsa --disable-outdev=alsa --disable-libopencore-amrnb --disable-libopencore-amrwb --disable-libcelt --disable-libdirac --disable-libfaac --enable-libfreetype --enable-frei0r --disable-libgsm --disable-libmp3lame --enable-libopencv --disable-libopenjpeg --disable-librtmp --enable-libschroedinger --disable-ffplay --disable-libspeex --enable-libtheora --disable-vaapi --disable-vdpau --disable-libvo-aacenc --disable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxvid
[2015-03-26 20:35:44,525] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavutil    50. 43. 0 / 50. 43. 0
[2015-03-26 20:35:44,525] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavcodec   52.123. 0 / 52.123. 0
[2015-03-26 20:35:44,525] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavformat  52.111. 0 / 52.111. 0
[2015-03-26 20:35:44,525] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavdevice  52.  5. 0 / 52.  5. 0
[2015-03-26 20:35:44,526] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libavfilter   1. 80. 0 /  1. 80. 0
[2015-03-26 20:35:44,526] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libswscale    0. 14. 1 /  0. 14. 1
[2015-03-26 20:35:44,526] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   libpostproc  51.  2. 0 / 51.  2. 0
[2015-03-26 20:35:44,692] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, asf, from '/mnt/music/Anberlin/Never Take Friendship Personal/01 Never Take Friendship Personal.wma':
[2015-03-26 20:35:44,692] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Metadata:
[2015-03-26 20:35:44,692] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     title           : Never Take Friendship Personal
[2015-03-26 20:35:44,692] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     artist          : Anberlin
[2015-03-26 20:35:44,692] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     WMFSDKVersion   : 11.0.5721.5251
[2015-03-26 20:35:44,692] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     WMFSDKNeeded    : 0.0.0.0000
[2015-03-26 20:35:44,692] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     WM/UniqueFileIdentifier: AMGa_id=R   727046;AMGp_id=P   558679;AMGt_id=T  7490967
[2015-03-26 20:35:44,692] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     publisher       : Tooth & Nail
[2015-03-26 20:35:44,692] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     WM/Provider     : AMG
[2015-03-26 20:35:44,692] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     track           : 0
[2015-03-26 20:35:44,692] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     album           : Never Take Friendship Personal
[2015-03-26 20:35:44,693] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     genre           : Christian Rock
[2015-03-26 20:35:44,693] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     WM/Year         : 2005
[2015-03-26 20:35:44,693] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     album_artist    : Anberlin
[2015-03-26 20:35:44,693] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     WM/EncodingTime : 1559979
[2015-03-26 20:35:44,693] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     WM/ProviderRating: 6
[2015-03-26 20:35:44,693] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     WM/ProviderStyle: Pop/Rock
[2015-03-26 20:35:44,693] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     IsVBR           : 0
[2015-03-26 20:35:44,693] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     MediaFoundationVersion: 2.112
[2015-03-26 20:35:44,693] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)   Duration: 00:03:31.34, start: 0.000000, bitrate: 160 kb/s
[2015-03-26 20:35:44,693] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg)     Stream #0.0: Audio: wmav2, 44100 Hz, 2 channels, s16, 160 kb/s
[2015-03-26 20:35:44,693] INFO InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Unrecognized option 'ba'
If anyone can point me in the right direction to recompile ffmpeg from source on BSD I believe I should be able to get this going. I've been rebuilding this jail a few times now from scratch. I'd love to be able to try out subsonic but without transcoding I can only play about half of my media files. I might end up switching to Plex if I can't get this working.
StanSmith
Re: Trouble with Transcoding
Postby phillipmcmahon » Sat Mar 28, 2015 9:28 am
phillipmcmahon
