Trouble Getting external access to Subsonic - local fine
Postby lukeclancy » Wed Apr 01, 2015 7:52 pm
hi folks
I'm wondering can anybody help me with the problem detailed below...ive subsonic running on a raspberrypi on my local network just fine.
But i can't seem to get externam access to it. I have tried all the port forwarding tips i can find, and indeed am getting an "all ok" from Subsonic re port forwarding (see attached)
I wonder has anybody any ideas?
Problem Description: Trouble getting external access to Subsonic - local works fine
Troubleshooting Steps: various helps on port forwarding
Playback Application and version: web, any
Subsonic Version: 5.2.1 (build 4428)
Server Version: jetty-6.1.x, java 1.8.0_06, Linux (66.7 MB / 145.0 MB)
Hardware Platform: Raspberry Pi 2
Java Memory Limit: Mac: can't find...
Problem Filename: n/a
Output from ffmpeg -i: Don't understand this
Last ten log file lines:
[4/1/15 10:30:00 AM UTC] INFO NetworkService Successfully forwarding port 4040.
[4/1/15 11:30:00 AM UTC] INFO NetworkService Successfully forwarding port 4040.
[4/1/15 12:30:00 PM UTC] INFO NetworkService Successfully forwarding port 4040.
[4/1/15 1:30:00 PM UTC] INFO NetworkService Successfully forwarding port 4040.
[4/1/15 2:30:00 PM UTC] INFO NetworkService Successfully forwarding port 4040.
[4/1/15 3:30:01 PM UTC] INFO NetworkService Successfully forwarding port 4040.
[4/1/15 4:30:01 PM UTC] INFO NetworkService Successfully forwarding port 4040.
[4/1/15 5:30:01 PM UTC] INFO NetworkService Successfully forwarding port 4040.
[4/1/15 6:30:01 PM UTC] INFO NetworkService Successfully forwarding port 4040.
[4/1/15 7:30:01 PM UTC] INFO NetworkService Successfully forwarding port 4040.
lukeclancy
Re: Trouble Getting external access to Subsonic - local fine
Postby gurutech » Sat Apr 04, 2015 9:53 pm
Check out the portforward.com site to manually port forward 4040 to your subsonic server. Make sure also that your subsonic server has a static IP address (or at least a reserved DHCP address).
gurutech
Postby lukeclancy » Sat Apr 04, 2015 10:18 pm
Trouble is, I'm on Mac and the portforwarding.com .exe doesn't work on a Mac. I followed their manual tutorial for my router, but it doesn't hel...
lukeclancy
Postby gurutech » Sun Apr 05, 2015 7:30 pm
portforwarding.com is a website. Go to the website and look up your router. It will explain in detail how to forward port 4040 (technically, it shows you how to forward ANY port, but you want 4040) to your Mac.
gurutech
Postby lukeclancy » Sun Apr 05, 2015 7:41 pm
Yes, as I said, I also went and followed their tutorial for my router. Still didn't work...
Sent from my iPhone using Tapatalk
lukeclancy
Postby alphawave7 » Sun Apr 05, 2015 7:54 pm
lukeclancy wrote:Yes, as I said, I also went and followed their tutorial for my router. Still didn't work...
There's three steps: 1) Fixed IP on the server, 2) Open server firewall to 4040, 3) Open port 4040 on router, test with server running at canyouseeme.org for port 4040.
Postby lukeclancy » Mon Apr 06, 2015 1:39 am
Ok, solved. Thanks for the help folks. It was the firewall on my raspi that was the issues. Even though it seemed none was installed by default, that didn't apparently mean the ports were open. So I needed to install a firewall in order to open 4040. Instructions here:
http://joshua14.homelinux.org/blog/?p=1688
lukeclancy
Postby lukeclancy » Mon Apr 06, 2015 9:08 am
I spoke too soon. It worked the first time I tried it, now back to the old timout...
lukeclancy
Postby lukeclancy » Mon Apr 06, 2015 9:17 am
Think I have solve that....make sure is Setting/Network that you don't have Subsonic's port forwarding 'helper' turned on...
lukeclancy
Postby gurutech » Tue Apr 07, 2015 6:00 pm
Also make sure your firewall doesn't have a "running" configuration, and a "permanent" configuration. If it does, make sure any changes you make to the "running" configuration are copied/saved to the "permanent" configuration before rebooting your firewall or restarting the service.
gurutech
Postby lukeclancy » Wed Apr 08, 2015 9:25 am
Thanks Sindre, will check that out.
(By the way, is there a good thread about directory structure for my music collection to enhance subsonic experience? I've got:
<A-Z>/<artist>/artist - album - trackno - song
But that seems to get me very patchy coverage in subsonic...anyway, wrong place for that Q...
lukeclancy
Postby gurutech » Wed Apr 08, 2015 2:54 pm
I've always done: /Music/Artist/Album/## Track Name.mp3 (where ## is the track number.)
gurutech
Postby mitrailer » Wed Apr 08, 2015 3:34 pm
lukeclancy wrote:Thanks Sindre, will check that out.
Use this guide http://monroeworld.com/android/subsonic (scroll down to the "About Music Organization and Display" part)
mitrailer
