Missing items from subsonic
Postby mgrant » Fri Feb 06, 2009 12:22 am
I have two nearly identical installs of Subsonic. Both installs are running on Ubuntu Linux with Apache Tomcat 6.0.18 and Java 1.6.0_10. Subsonic is 3.6 Build 806 on both.
My music collection is identical on both systems. Both systems run Ubuntu Linux. The only difference is that, on one system, the music is on an EXT3 partition and on the other system the music is on a VFAT partition.
I noticed yesterday that when using subsonic hosted on the VFAT system there were items that should have been there but were missing. I double-checked today and found that the missing items are actually present on the disk but just don't show up in subsonic.
I tried re-indexing manually and checked the subsonic.log for errors but still the missing items are missing.
Here's an example of a missing item:
/media/DATA/music/Mike Massé/
I suspect that there is some problem with the "é" because I have another folder named:
/media/DATA/music/Mike Masse/
and that works fine on both systems.
Any thoughts on how I can get the system with the VFAT partition to see ALL of the music?
-mg
mgrant
Postby mgrant » Sat Aug 01, 2009 11:57 pm
bump...
Anyone?
-mg
mgrant
Postby sindre_mehus » Sun Aug 02, 2009 7:22 am
Have you tried to change the locale? Please see this post:
http://forum.subsonic.org/forum/viewtopic.php?t=2014
Postby mgrant » Mon Aug 03, 2009 3:05 pm
sindre_mehus wrote:Have you tried to change the locale? Please see this post:
Thank You!
-mg
mgrant
