Remote control not working
Postby yoyoz » Sat Apr 11, 2015 12:53 pm
I use a subsonic player on android (local ip) to launch remote control, the picture show correctly, but the music never begin.
I have java 8 on windows (without firewall).
Have you any idea to correct this ?
yoyoz
Re: Remote control not working
Postby yoyoz » Wed Apr 15, 2015 9:04 am
i answer to myslelf.
You don't reinstall on your previous install.
You need to remove this (remove your database folder also), and reinstall.
It's works now on java 8 (v45)
yoyoz
Users browsing this forum: No registered users and 81 guests
