[MAC 5.21] Subsonic causing inactive memory build up, crash
Postby mtg105 » Fri Apr 24, 2015 4:59 am
Hi guys. I'm having a problem with Subsonic 5.21. I have a media server setup which I have raised the memory limit in the info.plist file to 512mb. When Subsonic is running, the inactive memory grows and grows (subsonic's actual memory usage never exceeds ~500mb) until the computer runs out of RAM and starts writing very large swapfiles. Then, when space for these swap files runs out, the computer crashes and the server goes down. I restart and the swapfiles are gone and all is well until the cycle starts up again.Can someone please help?
Q6600 @ 2.4ghz
6gb RAM
mtg105
Re: [MAC 5.21] Subsonic causing inactive memory build up, cr
Postby MikeLegit » Thu Apr 30, 2015 2:40 am
I see the same thing and I haven't been able to fix it.
Anyone know how can I go back to a previous version and save my *s and playlists? Can I use a previous .war file after i have upgraded? I've never had an issue until this release! :(
This forum is blocking my ISP with their aggressive filtering, so I can only login via my phone. After all my contributions (and more than 2X the recommend donation), the site admin is unwilling to help. You can find me at SmallNetBuilder Forums.
MikeLegit
Postby madhusker » Sun May 10, 2015 7:48 pm
What I had to totally remove my installation and re-install. Something got broken in the upgrade path. :? After the new install it works fine. I re-used my DB folder so it saved all my stars and playlists etc. Phew!
madhusker
Postby mtg105 » Sun May 10, 2015 11:41 pm
I'm still experiencing this on a fresh install of mountain lion. I even tried rolling back to 4.6 but no luck. Should I have to hack the memory limit or no? I'm sharing about 2tb of films, 2tb of movies, and 1tb of music. I don't know what to do, very frustrating!
mtg105
Postby madhusker » Sun May 10, 2015 11:55 pm
I guess try upping the limit to something unreasonable and see what happens. I cannot answer on iOS very well.
madhusker
