change default art when no cover found
Postby jeffpetersen » Sat Feb 07, 2009 9:15 pm
Thanks very much for the excellent work! I just wonder if it's possible to change the default art displayed when no folder.jpg or embedded art is found?
I searched the forum and poked around in the Subsonic folder, but didn't find anything.
jeffpetersen
Postby jannuh » Sun Feb 08, 2009 8:15 am
You can make a jpg for each map as you like, name it folder.jpg, ready!
jannuh
Postby jeffpetersen » Sun Feb 08, 2009 2:13 pm
Thanks for replying. What I meant was, where in the Subsonic install folder does the default cover art reside? I would like to change it to something else.
EDIT: In case it matters, I used the installer option for Windows.
jeffpetersen
Postby jonathanroz » Sun Feb 08, 2009 4:01 pm
In the folder
\subsonic\jetty\webapp\WEB-INF\classes\net\sourceforge\subsonic\controller
I have never replaced it myself, but I would assume swapping that file out and then restarting subsonic will take care of your issue.
jonathanroz
Postby jeffpetersen » Sun Feb 08, 2009 5:26 pm
:D
Perfect! Thank you very much.
jeffpetersen
