Cover Art Bug - Cover is not loading
Postby deejay2302 » Fri May 08, 2015 6:14 am
The problem: The cover we indeed downloaded but not displayed. You can see it but right above the chat. Only the big picture is not displayed. Why?
See picture:
21.681 Artists
58.141 Albums
674.091 Songs
5072,14 GB (~ 49.341 Hours)
deejay2302
Re: Cover Art Bug - Cover is not loading
Postby drchrill » Fri May 08, 2015 5:29 pm
I experienced a similar issue and after some digging I found it was due to a bug in the Java installation on my box (java-8-openjdk-amd64 on Debian GNU/Linux).
I got "java.lang.NoClassDefFoundError: Could not initialize class com.sun.imageio.plugins.jpeg.JPEGImageReader" and then found the root cause in the Debian BTS.
"openjdk-8: Missing JPEGImageReader functions in libjavajpeg.so"
https://bugs.debian.org/cgi-bin/bugrepo ... bug=760926
While waiting for a corrected package I "solved" it like this:
https://bugs.debian.org/cgi-bin/bugrepo ... =760926#35
/drchrill
drchrill
Postby deejay2302 » Fri May 08, 2015 8:26 pm
I do not use Linux Server. I have a Windows Server. What i can do? This stupid Subsonic will not change any cover art. :evil:
21.681 Artists
58.141 Albums
674.091 Songs
deejay2302
Postby deejay2302 » Sat May 09, 2015 4:08 pm
*Push*
21.681 Artists
58.141 Albums
674.091 Songs
deejay2302
Postby IdiotProof » Sat May 09, 2015 10:29 pm
Here things i found maybe help
Cover doesn't load if some commentary are attached (like focal, aperture ...) best is save your cover in .bmp to remove all shit and reload it before save it in .jpg
IdiotProof
Postby deejay2302 » Sun May 10, 2015 4:40 pm
But i use the internal Cover Art Search. They have no options to change file typ or search another file typ^^ Thats the problem. In older versions before 4.9 Beta 1 it works. All other newer versions have the same bug. :-/
21.681 Artists
58.141 Albums
674.091 Songs
deejay2302
Postby deejay2302 » Thu May 14, 2015 1:13 pm
*push*
21.681 Artists
58.141 Albums
674.091 Songs
deejay2302
Users browsing this forum: No registered users and 130 guests
