m4a files not playing
Postby waitek » Sun Feb 08, 2009 9:07 pm
MP3 files are playing fine. But I'm not having any luck with m4a files ripped as lossless files in iTunes.
I'm running a default Windows 3.6 install of Subsonic (downloaded Feb. 8).
Settings > Transcoding shows m4a > mp3 is enabled. Here are the specifics:
m4a > mp3
convert from m4a
convert to mp3
step 1: faad -w %s
step 2: lame -b %b -x - -
default: checked
enabled: checked
I'm using the web player. The m4a > mp3 for the player is checked as active.
The files show up fine. However, clicking the links doesn't lead to audible results.
Log output:
[2/8/09 12:51:06 PM PST] INFO DaoHelper Checking database schema.
[2/8/09 12:51:07 PM PST] INFO DaoHelper Done checking database schema.
[2/8/09 12:51:07 PM PST] INFO SearchService Automatic index creation scheduled to run every 1 day(s), starting at Mon Feb 09 03:00:00 PST 2009
[2/8/09 12:51:07 PM PST] INFO PodcastService Automatic Podcast update scheduled to run every 24 hour(s), starting at Sun Feb 08 12:56:07 PST 2009
[2/8/09 12:51:27 PM PST] INFO VersionService Resolved latest Subsonic final version to: 3.6
[2/8/09 12:51:27 PM PST] INFO VersionService Resolved latest Subsonic beta version to: 3.6.beta2
[2/8/09 12:51:27 PM PST] INFO VersionService Resolved local Subsonic version to: 3.6
[2/8/09 12:51:38 PM PST] INFO StreamController Starting stream admin@127.0.0.1:1292 (Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727))
[2/8/09 12:51:38 PM PST] INFO PlaylistInputStream Opening new song d:\music archive\Biogenx\01-intro-barry-hess.mp3
[2/8/09 12:51:38 PM PST] INFO MusicFileInfoDao Created music file info for d:\music archive\Biogenx
[2/8/09 12:51:40 PM PST] INFO StreamController Stopping stream admin@127.0.0.1:1292 (Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727))
[2/8/09 12:56:07 PM PST] INFO PodcastService Starting scheduled Podcast refresh.
[2/8/09 12:56:07 PM PST] INFO PodcastService Completed scheduled Podcast refresh.
[2/8/09 1:01:49 PM PST] INFO StreamController Starting stream admin@127.0.0.1:1286 (Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727))
[2/8/09 1:01:49 PM PST] INFO PlaylistInputStream Opening new song d:\music archive\ABBA\Thank You For The Music [Disc 1]\1-01 People Need Love.m4a
[2/8/09 1:01:49 PM PST] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\faad] [-w] [d:\music archive\ABBA\Thank You For The Music [Disc 1]\1-01 People Need Love.m4a]
[2/8/09 1:01:49 PM PST] DEBUG TranscodeInputStream Starting transcoder: [c:\subsonic\transcode\lame] [-b] [128] [-x] [-] [-]
[2/8/09 1:01:49 PM PST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\faad) *********** Ahead Software MPEG-4 AAC Decoder V2.6 ******************
[2/8/09 1:01:49 PM PST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\faad) Build: Apr 29 2008
[2/8/09 1:01:49 PM PST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\faad) Copyright 2002-2004: Ahead Software AG
[2/8/09 1:01:49 PM PST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\faad) http://www.audiocoding.com
[2/8/09 1:01:49 PM PST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\faad) Floating point version
[2/8/09 1:01:49 PM PST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\faad) This program is free software; you can redistribute it and/or modify
[2/8/09 1:01:49 PM PST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\faad) it under the terms of the GNU General Public License.
[2/8/09 1:01:49 PM PST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\faad) **************************************************************************
[2/8/09 1:01:49 PM PST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\faad) Unable to find correct AAC sound track in the MP4 file.
[2/8/09 1:01:49 PM PST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Assuming raw pcm input file : Forcing byte-swapping
[2/8/09 1:01:49 PM PST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) LAME version 3.96.1 (http://lame.sourceforge.net/)
[2/8/09 1:01:49 PM PST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) CPU features: MMX (ASM used), SSE, SSE2
[2/8/09 1:01:49 PM PST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Using polyphase lowpass filter, transition band: 17249 Hz - 17782 Hz
[2/8/09 1:01:49 PM PST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Encoding to
[2/8/09 1:01:49 PM PST] DEBUG InputStreamReaderThread (c:\subsonic\transcode\lame) Encoding as 44.1 kHz 128 kbps j-stereo MPEG-1 Layer III (11x) qval=3
[2/8/09 1:01:51 PM PST] INFO StreamController Stopping stream admin@127.0.0.1:1286 (Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727))
Thank you in advance for your help.
waitek
Postby waitek » Sun Mar 15, 2009 7:57 am
After additional research, it appears the problem is the Apple lossless format. There must be a transcoding solution, but I haven't found anything yet that works with Subsonic. Anyone else have any luck?
waitek
Postby volcs0 » Tue Mar 24, 2009 7:40 pm
volcs0
