Songs from subsonic getting garbled with other songs.
Postby froshaka » Fri May 22, 2015 9:27 pm
Problem Description: I recently moved from a Galaxy S3 to a Galaxy S5. I got my subsonic up and running on it and it sees my server without issue. I had noticed nothing wrong since I got the new phone a few days ago. This morning I tried to 'Pin' 3 songs and then set out to drive. In the middle of the first song, the song turned into a different song and then a few seconds later it was back again. When I say this, I dont mean that subsonic switched the song. I mean that the song that subsonic downloaded somehow had the music from other files in it. As if it misread the song on the server midway through attached another song to it and then switched back.
Troubleshooting Steps: I tried deleting and re-pinning the songs. The outcome changed but only in that the song got mixed up with other songs. It changed every time I tried to re-download.
Playback Application and version: Subsonic app for Android
Subsonic Version: 5.2.1 (build 4428) – March 4, 2015
Server Version: jetty-6.1.x, java 1.7.0_71, Windows 8 (59.2 MB / 122.7 MB)
Hardware Platform: Windows 8.1 64bit
Java Memory Limit: 500MB
Problem Filename: it affects all files downloaded now.
Output from ffmpeg -i: Was this to point to an mp3 that exhibited the symptom? I did that. The song itself is fine when played from my computer its only how subsonic is downloading it.
C:\subsonic\transcode>ffmpeg.exe -i C:\Music\Coil\1991_The_Snow\01_Driftmix.mp3
ffmpeg version N-61599-gce9d3da Copyright (c) 2000-2014 the FFmpeg developers
  built on Mar 18 2014 22:01:44 with gcc 4.8.2 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av
isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab
le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp
e --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --ena
ble-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-l
ibopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libsp
eex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aa
cenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavp
ack --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable
-zlib
  libavutil      52. 67.100 / 52. 67.100
  libavcodec     55. 52.102 / 55. 52.102
  libavformat    55. 34.101 / 55. 34.101
  libavdevice    55. 11.100 / 55. 11.100
  libavfilter     4.  3.100 /  4.  3.100
  libswscale      2.  5.101 /  2.  5.101
  libswresample   0. 18.100 /  0. 18.100
  libpostproc    52.  3.100 / 52.  3.100
Input #0, mp3, from 'C:\Music\Coil\1991_The_Snow\01_Driftmix.mp3':
  Metadata:
    title           : Driftmix
    artist          : Coil
    album           : The Snow
    track           : 01/06
    date            : 1991
  Duration: 00:02:37.44, start: 0.025057, bitrate: 320 kb/s
    Stream #0:0: Audio: mp3, 44100 Hz, stereo, s16p, 320 kb/s
Last ten log file lines:
[5/22/15 1:40:16 PM MDT]   INFO   PlayQueueInputStream   Mobile listening to "1999_Monsters & Robots\01-10- Stun Operator.mp3"
[5/22/15 1:40:21 PM MDT]   INFO   PlayQueueInputStream   Mobile listening to "1999_Monsters & Robots\01-11- Scapula.mp3"
[5/22/15 1:40:26 PM MDT]   INFO   PlayQueueInputStream   Mobile listening to "1999_Monsters & Robots\01-12- Nun Chuka Kata.mp3"
[5/22/15 1:41:07 PM MDT]   INFO   PodcastService   Starting scheduled Podcast refresh.
[5/22/15 1:41:07 PM MDT]   INFO   PodcastService   Completed scheduled Podcast refresh.
[5/22/15 2:36:18 PM MDT]   WARN   NetworkService   Failed to create port forwarding.
[5/22/15 2:55:38 PM MDT]   INFO   PlayQueueInputStream   Mobile listening to "1991_The Snow\01_Driftmix.mp3"
[5/22/15 2:55:43 PM MDT]   INFO   PlayQueueInputStream   Mobile listening to "1991_The Snow\02_Answers Come In Dreams I.mp3"
[5/22/15 2:55:58 PM MDT]   INFO   PlayQueueInputStream   Mobile listening to "1991_The Snow\03_Out In The Cold.mp3"
[5/22/15 2:56:28 PM MDT]   INFO   PlayQueueInputStream   Mobile listening to "1991_The Snow\04_As Pure As .mp3"
[5/22/15 2:57:08 PM MDT]   INFO   PlayQueueInputStream   Mobile listening to "1991_The Snow\05_Answers Come In Dreams II.mp3"
[5/22/15 2:57:48 PM MDT]   INFO   PlayQueueInputStream   Mobile listening to "1991_The Snow\06_The Snow.mp3"
So has anyone ever experienced symptoms of this before?
froshaka
Re: Songs from subsonic getting garbled with other songs.
Postby degan6 » Thu May 28, 2015 7:12 am
Well this is interesting.
When you play the files through the web interface does it have the problem?
Do still have your old phone or another phone that you can install the same app on. If so does it have the problem?
What other applications do you have on your computer that help you mange music?
Are other people using your computer while your using it as a server?
Are other people using subsonic?
Download Dsub for android and see if you have the same problem.
This feels like a problem with your server.
degan6
